Cooling Problems continue...any ideas?
Old Jun 25, 2002 | 08:26 PM
akageals's Avatar
Guys,
My cooling problem continues.
I changed the upper and lower radiator hoses AND the thermostat/gasket. I'm still getting the same behavior. I used a MAZDA thermostat so no problems there. When I stop the car and open the hood the air coming off the radiator fan is VERY hot...makes me think that the radiator is working. I wonder if my water pump could be causing this. It must be either the water pump OR, heaven forbid, the radiator (damn expensive).
To Recap:
'87 TII
Gets hot at highway speeds (above 45 or so)
Cools off when you slow down
A/C makes condition worse
All stock shield, belly tray, etc. are in place
Using stock fan
Any Ideas?
Todd
Old Jun 25, 2002 | 08:29 PM
'Vert in Vegas's Avatar
Try removing the belly pan. See if letting more hot air escape works.
Old Jun 25, 2002 | 08:33 PM
NZConvertible's Avatar
I'm a boost creep...
Re: Cooling Problems continue...any ideas?
These were my two suggestions the first time you asked this! Remove and inspect the pump, remove and flush the radiator.
Old Jun 25, 2002 | 08:35 PM
Escape? Um, wrong side of the radiator...
Besides, that will only reduce the amount of air going into the radiator at speed and worsen the problem.
Old Jun 25, 2002 | 08:46 PM
banzaitoyota's Avatar
What Subscription?
I concur with NZconvertible on this. Do the basics first.
Old Jun 25, 2002 | 08:47 PM
akageals's Avatar
Yeah.....I know NZ....I was trying to do the easiest stuff first.....plus I already had the new hoses and the thermostat. I'll pull that pump on Thursday and let you know what I find out. After the pump comes the radiator (cringe)!
Thanks,
Todd
Old Jun 25, 2002 | 08:50 PM
There's a write-up at www.fc3s.org if you need one. Good luck.
Old Jun 25, 2002 | 10:55 PM
Six Rotors's Avatar
Did you test the thermostat before you installed it?I have come across NEW MAZDA thermostats which did not open to the spec opening.I always test them before installation now.
Old Jun 26, 2002 | 02:31 PM
akageals's Avatar
I did not test it...however I did try two different MAZDA thermostats and neither made a difference.
Todd
whinin
Mar 30, 2019 07:53 PM
sherff
Sep 12, 2015 12:22 PM
tiger18
Sep 3, 2015 08:27 PM
rx7shirley
Sep 2, 2015 02:11 PM
ray green
1st Gen General Discussion
Sep 2, 2015 06:35 AM
