buzzer!!!
Old Jul 14, 2010 | 09:06 AM
drift2supra's Avatar
buzzer!!!
does anyone have this problem? when i turn my ignition this buzzer goes off and stays on even after i turn my car on neve goes away, can anybody help way anoying prob,
Old Jul 14, 2010 | 10:56 AM
RotaryRocket88's Avatar
Top Down, Boost Up
That would be the car telling you its low on coolant or oil. If you're sure both are topped off, and the coolant has been bled of any air, check the wiring and sensors. The coolant level sensor is on top of the radiator, and the oil level sensor is on the driver-side of the oil pan.
Old Jul 14, 2010 | 12:29 PM
Kentetsu's Avatar
It would help to know the year of the car
If you have a 1st gen:
1. Check the fluid levels as advised above.
2. If all that is good, then the most likely suspect is the Oscillator. These often cause issues when they get wet, and sometimes it will go away on its own, but often not. Most of us just unplug them. This gets rid of the audible alarm, but you will still have dash lights if any of your important fluids get low. It is located right in front of the battery, a small black box that looks just like a relay. It says Oscillator right on it.
Old Jul 16, 2010 | 02:44 AM
thanks
yea i have a second gen, yea it was the coolent that was a bit low, thanks alot everybody,
c0rpse
16
Sep 25, 2015 11:33 AM
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
86glxNA
Sep 15, 2015 04:20 PM
The1Sun
Sep 7, 2015 10:21 PM
