s5 clear signal question and rear end?
Old Jul 13, 2010 | 07:14 PM
mylucky7's Avatar
NY s5 clear signal question and rear end?
i have 2 questions, first will s5 clear signals fit on a s4 rx7? if they do can i just get the covers or do i need the whole assy.? my next question is i own an 86 and the guy i bought it from said he put a turbo2 rear end in it for the lsd, but my car is a gxl and came with lsd? what would be the gain from the swap? how can i tell if it really has been swaped?
ok that was like 5 questions, but all help is useful. thanks in advance
Old Jul 14, 2010 | 09:12 AM
Aaron Cake's Avatar
Engine, Not Motor
You can't bolt on a TII LSD without other major changes.
Don't know off hand about the clear lenses, but I suspect they fit.
Old Jul 14, 2010 | 11:06 AM
RotaryRocket88's Avatar
Top Down, Boost Up
TII rear ends are larger and stronger than their NA counterparts, but as Aaron pointed out, you can't just bolt in the rear end alone. TII half shafts and a custom driveshaft must also be used. Maybe the previous owner did do this, but maybe he didn't know what he was talking about.
And no, you can't use S5 turn signal lenses on an S4 bumper. If you look at the S5 RX-7 in the forum's banner, you'll see that the S5 ones are thinner.
Old Jul 14, 2010 | 08:10 PM
mylucky7's Avatar
NY
thanks for the help but is there a way to tell if it is a turboII rear end (shape, serial #, or measurement)?
Old Jul 15, 2010 | 09:57 PM
misterstyx69's Avatar
Retired Moderator, RIP
I think you can tell by the number of Ribs on the back of the Diff.
7 and 11.Not sure which is which.TII is heavier,I know that.
The TII LSD and the N/A LSD have tags,on the Filler nut that say"fill with LSD type fluid only"
The TII Lsd's are beefier and the half shafts are also,
If you put in an N/A Lsd you can't use the TII Half shafts or Drivehaft,,they all have to be the same.(for TII or N/A),BUT you can use either setup with the 4 or Five lug rear spindle assemblies as the Splines on teh half shafts are the same.
Old Jul 16, 2010 | 07:27 PM
mylucky7's Avatar
thanks misterstyx69, does any one have a tII and can count the ribs on the back to see if it has 7 or 11?
Old Jul 16, 2010 | 07:36 PM
Top Down, Boost Up
A search of the 2nd gen section says the TII case has more ribs, which makes sense seeing as it is larger.
Old Jul 17, 2010 | 12:42 PM
mylucky7's Avatar
thanks ill check it out today
Old Jul 18, 2010 | 10:02 PM
Top Down, Boost Up
For what it's worth, I had my car in the air today and counted 9 ribs on my NA LSD. So if yours has 9, it's from an NA.
mazdaverx713b
48
Apr 21, 2016 06:45 AM
