My new (ghetto-fabulous) IC setup
Old Jul 11, 2010 | 01:53 PM
beefhole's Avatar
Boosted. I got BLOWN!!!
Talking My new (ghetto-fabulous) IC setup
You can see my old even-more-ghetto-fabulous setup in my profile album. I decided I didn't like it anymore. Most importantly, the piping was in the way of re-mounting the anti-swaybar previously removed by who knows. I misjudged the size of the IC I bought, but I was able to make it work and had some left over piping and coupling too.
In this first picture I had to re-use this old pipe (slightly under 2.5 inches) because again, I misjudged a few things and didn't think to buy a new 90 degree pipe. Anyway...
Underneath...
Old Jul 11, 2010 | 01:58 PM
beefhole's Avatar
Continued...
There is already a hole conveniently here from the factory. It was slightly under 2.5 inches, but I shoved a piece of smaller pipe in it, and wiggled it around expanding the metal and was able to easily get the new piping in.
Here is my proudest achievement! I kept the battery in place, but moved the leading coils over. Just enough room here to get the piping in.
Got some crazy bends here. It's certainly not optimal, but will work. I have to source a new TB elbow.
Just gotta get t-bolt clamps and a better turbo outlet pipe.
Old Jul 11, 2010 | 02:42 PM
Spirit-RE's Avatar
Hey it works
I like how the pipe is on the underside between the turbo and intercooler.
For the throttle body elbow, you could just cut the 'face' off that and weld a different angle pipe on that.
Old Jul 11, 2010 | 03:52 PM
iani1.1's Avatar
DILLIGAF
Nice setup but too many bends for my taste. You can use the NA throttle elbow. It fit just fine when I did mine.
Old Jul 11, 2010 | 09:53 PM
beefhole's Avatar
Originally Posted by nate91242
Hey it works
Was thinking this. Or ultimately I'll find the greddy elbow, but that always costs too much.
I had to work with what I had, which meant running pipe underneath. The most common method is via behind the passenger light area above. Ultimately my goal was to not hack anything up. All i had to do was enlarge a hole, and bend some metal underneath. Not a lot of work for me. I prefer a different than usual setup.
This is also an idea.
Like mentioned, that's a major U-turn in air path right at the TB elbow. The next thing will be to fix that area.
I did some measuring and bought some pipe lengths and various couplers, hoping I could make something work; I didn't plan this out very thoroughly. For now I am happy.
Old Jul 12, 2010 | 05:52 PM
FelixIsGod29X's Avatar
Manual Rack
I like the set-up. I wouldn't mind going the same route you did but in the future. How much did the piping/intercooler run you?
I got a n/a throttle body elbow if you need it beefhole. I can bring it to the next function 7 meet if your going. No charge.
Old Jul 12, 2010 | 05:55 PM
beefhole's Avatar
^THIS! We will coordinate during the coming days
Old Jul 12, 2010 | 09:47 PM
Manual Rack
Soo how much did the piping/IC cost roughly?
Once it's fully clamped and ready to roll be sure to tell us what you think of the set-up over your old set-up. - Nick
Old Jul 13, 2010 | 11:43 AM
beefhole's Avatar
I paid $325ish for everything, but I did order too much extra pipe. However, I reused an old pipe and 1 coupler so it's a wash I suppose. The killer was 1 elbow coupler (which is hard to see). 2inch 90 degree to 2.5 inch off the turbo outlet. Those are expensive!
I guess the price was OK. Most e-bay kits are $300-$400
Old Jul 14, 2010 | 11:32 AM
sharingan 19's Avatar
Rotary Revolutionary
Very nice, I'm working on something vaugely similar, except using an EVO IC and hard piping from various turbo cars in the junk yard. I was wondering what to do about the TB elbow, N/A....brilliant!
eplusz
15
Oct 7, 2015 04:04 PM
spokanerxdude
Megasquirt Forum
Oct 6, 2015 12:28 PM
