Rtek Forum Discuss the Rtek 2.0 and other Rtek ECU's
Rtek Anti flooding, what TPS % does it kick in at?
Old Jul 11, 2010 | 12:29 AM
AUGieDogie's Avatar
So my 87 turbo was a bit flooded and I noticed that the anti flooding function didn't seem to be working. I noticed that my TPS was only reading 93% soooooo when does it kick in? I had to pull the fuse to get it to start.
Old Jul 11, 2010 | 01:08 AM
arghx's Avatar
rotorhead
I thought it only worked on s5 cars?
Old Jul 11, 2010 | 02:11 AM
solareon's Avatar
supposed to be a feature on the s4 cars as well. I thought it wasn't until it was 100% or like 99%. gotta ask turbo2ltr
Old Jul 11, 2010 | 12:36 PM
Nick_d_TII's Avatar
I know mine TPS goes to like 92%, but it works when I hold my foot to the floor and crank, or at least I think it does, it fires up when it seems slightly flodded?... It seems like if I step on the gas while its cranking it cuts fuel too... sometimes requires me to fiddle with the pedal a little but it starts everytime.
Old Jul 11, 2010 | 06:07 PM
turbo2ltr's Avatar
If I recall correctly the trigger point is 50%
Old Jul 14, 2010 | 08:14 PM
AUGieDogie's Avatar
Alrighty then, so does it cut ALL fuel. I'm getting 1.5ms pulse on my injectors with the accelerator pressed to the floore (93%)
Old Dec 31, 2010 | 04:20 PM
sharingan 19's Avatar
Rotary Revolutionary
Would be nice to know.... That feature does not work on my car. The TPS sees 74% max, which I thought was the problem, but if its supposed to trigger @ 50% that should be a non-issue. I still have my fuel cut switch hooked up, so its not that big a deal, but it would be nice to use the ecu feature instead.
Old Apr 25, 2011 | 01:34 AM
s30z's Avatar
i have the same problem, so anyone know the correct tps reading for the flood clear feature?
Old Apr 30, 2011 | 07:19 PM
RotaryRocket88's Avatar
Top Down, Boost Up
It's on stock S5 ECUs only, but S4 Rtek'd ECUs have it added on.
It works on my car with the TPS reaching 94% max, but I have rarely needed to use it. Once you get enough fuel out of the start map, it shouldn't flood anymore.
LongDuck
Oct 7, 2015 08:12 PM
Einheri
Oct 7, 2015 12:23 PM
