optimal running temp
Old Jul 8, 2010 | 10:22 PM
canonize-ryda's Avatar
on my 86 na i finally got my temp gauge to read. ,my cars warms up within a fews minutes all the way to 170 degrees celcius. or im assuming guage only goes to 150 and then red. so what is the optimal running temp for my s4 engine. thanks
Old Jul 9, 2010 | 09:12 AM
Aaron Cake's Avatar
Engine, Not Motor
You mean 170 defrees F. 170 C is quite hot, considering thermostat temp is 86 degrees C.
170 F is a bit cool at 76 C. Make sure your thermostat is not stuck open.
Where is your gauge sender?
Old Jul 9, 2010 | 07:34 PM
i do mean 170 c it says c on my guage. its a aftermarket guage. and my sender is the stock sender i just replaced it with a new one. and my thermostat may be stuck hwo would be the easiest way to tell? the guage it self goes to 150 then starts red but i belive it between 160-170 c its a oil temp not coolant( i think)
Old Jul 9, 2010 | 07:50 PM
funkjaw's Avatar
So is this gauge hooked up to your coolant or oil?
Old Jul 10, 2010 | 12:19 AM
MadScience_7's Avatar
Too old for this
If your water temp is really at 170°C(340°F) you have serious problems. Check the units on the gauge and make sure the sender is working right.
Old Jul 10, 2010 | 10:46 AM
Aaron Cake's Avatar
Engine, Not Motor
You can't run an aftermarket sender on a stock gauge. The gauge is matched to the sender. Your gauge isn't reading correctly.
Old Jul 10, 2010 | 09:43 PM
its an aftermarket guage not sender... i bought a new sender for my car off the net. and the stock guage is not hooked up. but perhaps the after market guage is misreading and maybe i should see if my stock guage will read it correctly. and i belive it coolant temp since when i remove the temp sender(right beneath the pressure sender) coolant come out not oil. also the car has never smoked or cut out or anything has gone wrong due to this i just wondering if my guage may not be working correctly.
Old Jul 10, 2010 | 10:08 PM
RotaryRocket88's Avatar
Top Down, Boost Up
Is the aftermarket sender intended for the aftermarket guage? There are all sorts of senders available, but only a handful will have the correct resistance sweep for your gauge.
Old Jul 11, 2010 | 09:28 AM
Aaron Cake's Avatar
Engine, Not Motor
Unless the sender came with that gauge, it is mismatched. The sender and gauge are matched.
Old Jul 12, 2010 | 01:40 PM
yea its a oem sender. ill try hookin the stock guage up to see if it reads arounf the mid range and just make shure it not over heating. (i just drove it over 400 miles nonstop with no smells or anything like that. just felt like at 80 my injectors where surging once in a while.(maybe my elimination bolt for the pd)
Old Jul 12, 2010 | 03:06 PM
Top Down, Boost Up
You can't use an aftermarket gauge with a stock/OEM sender.
sherff
Feb 24, 2019 12:09 PM
C. Ludwig
Jan 30, 2019 06:31 AM
dkwasherexd
May 27, 2017 04:51 AM
CaptainKRM
14
Aug 26, 2015 09:52 PM
befarrer
Microtech
Aug 22, 2015 05:52 PM
