more power
Old Jul 6, 2010 | 08:29 PM
elk4's Avatar
WA more power
new to the forum i am a new owner of a 81 rx7 love the car to death and was wondering if there are any little tricks out there to make it any snapper or responsive in the lower rpms. timing,carb, ooo ya i do not know if you are suppose to fill the secondary or not but i fill them just a little bit i was wondering if i can adjust them just a little thanks for any help
Old Jul 7, 2010 | 12:14 AM
mar3's Avatar
Administrator
Redo the exhaust system...don't mess with the Nikki carb unless you're already a racer who can tune carbs.
Mario III
Old Jul 7, 2010 | 02:48 PM
elk4's Avatar
i think there is all ready a header on and it is straight pipe to muffler, can i put a spacer between the carb and intake i heard that it will give it some more power but that was with a different car, no i am not a racer i am just trying to get a little more out of my car without spending much money. what about timing.
Old Jul 7, 2010 | 06:14 PM
rxtasy3's Avatar
spacers don't add power. get an aftermarket carb and intake for ur egnine and a free-er flowing exhaust. the when the engine gives out, tear it apart and port it.
Old Jul 7, 2010 | 11:57 PM
elk4's Avatar
thanks i have look and look and the only carbs i can find are weabers and the price tag is hight because you have to bye a intake and carb kit to convert you are looking at about $700-$800 thats just a little out of my price range i only payed $400 nothing wrong with it its red that is a problem for me
Old Jul 8, 2010 | 08:47 AM
84 GSL's Avatar
It's supposed to do that.
I bought a used Weber 45 DCOE on this forum with intake for 400$. This is a good place to look for stuff like that. Keep your eyes peeled in the classifieds.
Old Jul 8, 2010 | 11:22 AM
Kentetsu's Avatar
Carb: www.sterlingmetalworks.com
You need to confirm what you have for exhaust. It should be easy to see if there is a header on it, just look. Also check if there are any catalytic converters on the car (these are restrictive).
Throw on some lower profile tires, which is an easy way to reduce the gear ratio and makes the car quite a bit zippier.
There are also some ignition modifications that you can make. Look in the 1st Gen FAQ section for details.
Installing an electric fan can make the car a bit more lively in the lower gears.
Removing anything that doesn't have to be on the car can lighten it up, which makes a big difference. There's close to 100 Lbs of junk under the hood that you might be able to live without (emissions, air pump, air conditioning, etc.).
My car has had all of this done, plus a lot of suspension parts from www.re-speed.com
Here's a short video from our races last weekend, the first three clips are of my car:
http://www.youtube.com/watch?v=ZKNjkywj1Q0
Old Jul 8, 2010 | 01:41 PM
elk4's Avatar
yes header for shier, there is also a electric fan no motor fan i was looking and the air pump is still there but it is hooked up to the intake and the carb if i take it off will there be any issues with it and that only leves 1 belt is this right
Old Jul 9, 2010 | 02:31 PM
elk4's Avatar
so can i take it off or not the air pump that is
rgordon1979
40
Mar 15, 2022 12:04 PM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
