Rtek Forum Discuss the Rtek 2.0 and other Rtek ECU's
Rtek Rev limiter - fuel cut or ignition?
Old Jul 6, 2010 | 05:20 PM
Black Knight RX7 FC3S's Avatar
Turbo power, activate!
when you adjust the rev limit to be higher, is it using the stock fuel cut, or ignition cut?
Old Jul 6, 2010 | 05:32 PM
lastphaseofthis's Avatar
My job is to blow **** up
s5 N/A
Increase rev limit to 9200:
The user can select stock rev limit or increase the limit to 9200 RPM for racing applications. The rev limit is not variable. The only options are stock or 9200 RPM.
http://pocketlogger.com/index.php?pi...cu=S5NA#increv
s5 Turbo II
Increase rev limit to 8700:
The user can select stock rev limit or increase the limit to 8700 RPM for racing applications. The rev limit is not variable. The only options are stock or 8700 RPM.
S4's dont support changing your rev limit.
i am pretty sure that DOESN"T answer your question, but i ASSUME it still cuts the fuel like stock, just adds a few hundred rpm on top.
Old Jul 6, 2010 | 11:40 PM
if it uses the stock ecu then i guess it uses the stock fuel cut too then.
Old Jul 7, 2010 | 08:39 AM
sharingan 19's Avatar
Rotary Revolutionary
S5's get increased rev limit!?!? NOT fari!
Not that you're making any power there, but still....
Old Jul 10, 2010 | 02:19 PM
2RotorSpeed's Avatar
rottary89
All I have to say is, I love being able to hit the rev limit at 8.5K while drifting, and having that extra push for the car instead of shifting gears in certain situations is great!
Old Oct 3, 2010 | 01:29 PM
Chriz88DX's Avatar
my s4 na 326 ecu with version 2.0 can change the rev limiter helps alot with my bridge port
C. Ludwig
Jan 30, 2019 06:31 AM
alphawolff
Nov 17, 2015 05:57 PM
morataya
Microtech
Aug 17, 2015 01:04 PM
armans
Aug 15, 2015 09:08 PM
