Turboing
Old Jul 2, 2010 | 10:02 PM
Silver Tuxedo's Avatar
Spy Hunter
WA Turboing
Can you set up a turbo on a 13B that is not set up from the factory as a Turbo, would that damage the engine in any way?
Old Jul 3, 2010 | 10:28 AM
Aaron Cake's Avatar
Engine, Not Motor
Copied directly from the FAQ:
Can I swap a Turbo engine/Jspec engine/13BT/etc into my Non Turbo?
Yes, check these links:
https://www.rx7club.com/forum/showth...threadid=26647
http://www.rotaryresurrection.com/ro...conversion.htm
What Turbo kits can I add onto my non turbo RX-7?
There are no longer kits formally made at the time of this post, however there are companies from time to time that do make available non turbo to Turbo Kits. Because most of these companies stop building the kits, or go out of business in short time, it is impossible to keep active links for them.
Most people that turbo a non turbo make their own kits:
Using the stock TII turbo, exhaust manifold with spacer, NA intakes and NA ECU:
http://www.aaroncake.net/rx-7/naturbo.htm
https://www.rx7club.com/forum/showth...threadid=88540
https://www.rx7club.com/forum/showth...threadid=88758
https://www.rx7club.com/forum/showth...hreadid=124232
http://users2.ev1.net/~ccoutts/turbo..._a_project.htm
http://www.aaroncake.net/rx-7/projecttina
Using the stock TII turbo, exhaust manifold, intakes, ECU:
http://forum.teamfc3s.org/showthread.php?t=37694
Turbo-NA Forum:
http://www.aaroncake.net/forum/forum...urbocharged+NA
FD7KiD
15
Feb 26, 2021 10:12 PM
Th0m4s
Feb 26, 2019 02:04 AM
C. Ludwig
Jan 30, 2019 06:31 AM
ChrisRX8PR
Aug 21, 2015 01:56 PM
