What are Wastegate and Pre-control pills? (I searched)
I can find all kinds of reference to them, but no real description of what they are. I gather they are part of the turbo control system, but other than that, I'm lost.
They are small metal ***** or "pills" that have very small holes in them. They are fitted inside the vacuum lines that lead to the wastegate and precontrol actuators. There job is to limit the amount of air that flows to those devices. Here's a pic of the lines they are in:
As you open the intake and exhaust you are flowing more air and will need to replace these pills in order to properly control boost. Some people use jets from Holley Carbs as replacements and others just replace the pills with adjustable needle valves (referred to as the Home Depot Manual Boost Controller).
Captain Hook
13
Oct 4, 2015 06:35 PM
