Max torque to stock FB (GSL) tranny?
Old Jun 27, 2010 | 05:16 PM
jbalgley's Avatar
Hi --
I just bought an 84 GSL that had previously been converted to all-electric. It is not working now. The current (non-working) motor/batteries/controller appear to have been able to generate as much as110-140 ft/lbs of torque ... at 1 RPM, heh-heh.
I am looking into upgrading the batteries/controller in the short term so the motor will be able to generate as much as 225 ft/lbs. In the long term, maybe more.
What's the most torque anyone has applied to a stock tranny?
If you think this much torque will quickly break the stock tranny, do you have any recommendations for what to replace it with?
Thanks in advance.
--Jon (newbie)
Old Jun 28, 2010 | 10:04 PM
Cordt's Avatar
that will probably destroy it pretty quickly. along with the rear end.
from what i understand you dont even need a transmission with an electric motor? what kind of RPM does that thing reach?
Old Jun 29, 2010 | 11:04 AM
jbalgley's Avatar
Thanks for the reply.
I guess I'll keep the torque low for a while, so I get to drive it a while before it breaks and I have to replace it.
No, you don't need a transmission, strictly speaking, because the torque is available right away (less/no need to gear down or rev up).
Electric motors generally have fairly low max RPM. My motor's max is about 5000 rpm. So if you go without a transmission, then you need to make the gear low enough so that the torque can still start the car moving (usually not a problem), and high enough to get the desired top speed.
OTOH, maximum efficiency is generally at or near top RPM. So, within reason, you downshift for economy and upshift for power. (!)
As I understand, anyways. I'm an electric car newbie too.
Old Jun 30, 2010 | 05:40 PM
Cordt's Avatar
just have to add, this is a really badass project. i really hope you post some pictures and/or videos of this thing in the future. keep me updated
Old Jul 1, 2010 | 10:32 AM
Aaron Cake's Avatar
Engine, Not Motor
That is an AWESOME project.
At those torque levels I doubt you will have much problem with the stock drivetrain. You'll likely leave it in 2nd gear anyway. Stock tires will break free before you damage the drivetrain.
If you are going to be going to a larger motor that can really belt out the torque (what motor and controller?) then you can upgrade to the 2nd gen TII R-type transmission without too much trouble. The rear end will likely still be OK.
Old Jul 1, 2010 | 12:33 PM
jbalgley's Avatar
Motor is ADC FB1-4001. Controller TBD.
Likely to use racing slicks (Kumho 710s), though. So quite a bit more grip.
See pictures here:
http://cbfamily.smugmug.com/Other/10...10757321_YhXVo
Old Jul 3, 2010 | 10:41 AM
Aaron Cake's Avatar
Engine, Not Motor
OK, so with the slicks, you will certainly need a transmission upgrade. The TII transmission bolts in without only a few minor changes. As for the rear end, you are probably still OK. If not, I think Granny's Speed sells a kit to put in the 9 inch.
Hehehe...You have Rudmen Regs...
C. Ludwig
Jan 30, 2019 06:31 AM
The1Sun
Mar 18, 2018 11:08 PM
immanuel__7
89
Sep 5, 2015 10:23 AM
Snook
Aug 15, 2015 08:18 AM
