Fabrication Post your questions and projects on Fabrication of Interior or Exterior or custom audio and electronics here.
CNC'd Keychain
Old Jun 25, 2010 | 04:51 AM
levelzero's Avatar
CNC'd Keychain
Things have settled down a little in the shop so I decided to make myself a little something. I've been wanting a new keychain for my rx7 keys and I figured this would be a good excuse to use up some brass I had in the shop. From design to finished it took about 3 hours total, although I was very conservative with my feed rates as I don't work with brass often. Since I had the space on the material I also made some matching emblems to go on my fenders.
Setting up the material. This isn't ideal but for a quick job it works as long as you don't cut too aggressively.
Part way through engraving the design.
Finish engraving.
Finished Cutting
Back side. You can see how the parts are only cut 99% of the way through.
After deburring and finishing.
Close up. You can see some faint lines where I need to adjust the cutting paths to overlap better.
Installed. It's not 100% perfect but I'm quite happy with it.
Because I had a spare set, I polished one of the sets of fender emblems to see the difference. I couldn't be happier with the result and just hope they look as good on the car as they do on my desk. Polished one is on the right.
While I was waiting for the parts to cut I unloaded one of my subplates. I thought this looked pretty cool so I snapped a picture.
Old Jun 25, 2010 | 07:33 AM
waldog's Avatar
Whipping thru traffic.
Holy crap dude, those are awesome.
If you're ever willing to donate one of the extra fender ones, let me know. I keep my 7 key by itself cause it's to good for the other keys.
Old Jun 25, 2010 | 07:42 AM
Stevetotheo's Avatar
Steve-O
What did you design that in? Any chance I could have a copy of the
file? Im building my own cnc and would love to use that as one of my first tests when its done.
link to my CNC build
www.stevetotheo.weebly.com/cnc-space.html
Thanks!
Old Jun 25, 2010 | 11:42 AM
otaku85's Avatar
sick would love to have one
Old Jun 25, 2010 | 01:19 PM
levelzero's Avatar
My 7 keys are with all my other keys but for the longest time I was using an Ecotec keychain I made but it just felt wrong.
Thanks!
All my design work is done in solidworks. I think I've actually read your blog before. One of my back burner projects is a automated polisher powered by an arduino. I wasn't planning to have it interpret gcode though, I was just going to hardcode the paths into the sketch. Right now I'm still designing the linear motion portions though.
What are you planning to use for the cad/cam side of things?
There is a really good chance I'm going to make some more. I've been wanting to add more rotary specific products to my catalog.
Old Jun 25, 2010 | 01:44 PM
Tessai76086's Avatar
hukd in fonikz
should take a look at FeatureCAM its a bit on the expensive side but well worth it. Will auto pick tools, paths, and feed rate. all you have to do is draw and hit send.
Old Jun 25, 2010 | 02:21 PM
Alex_n/a's Avatar
rx7 almost a religon
you should make something similar but instead of the "M" use a "rx7" or just "7" that would be so sick to have that keychain are you planning on selling some or just for yourself?
Old Jun 25, 2010 | 02:24 PM
levelzero's Avatar
FeatureCAM sounds interesting and I'll definitely have a look at it.
Old Jun 25, 2010 | 02:32 PM
levelzero's Avatar
Yeah I was actually thinking a design with a 7 in it would look nice. I did the old school Mazda logo because I personally have always liked it. When I have some extra time I'll play around with it though.
I'm not a vendor so I can't offer them for sale or speculate publicly on selling them. But I can say that I manufacture automotive parts for a living and this is the sort of thing I would make and sell even though it was originally designed for my own personal use.
Old Jun 25, 2010 | 02:46 PM
Steve-O
And here i thought no one read it. LOL. I havent decided on the cad cam portion. There are plenty out there sure enough and with the way my project has gone you cant get too set on anything or else you run the risk of not being able to get it to work with all the rest of the build Ive cobbled together. I really wanted to figure out how to get linux EMC to talk to the USB port but there are real time communication issues. Any way. Let me know if you crank out anything else cool!!
Old Jun 25, 2010 | 03:02 PM
levelzero's Avatar
https://www.rx7club.com/showthread.php?p=10077687
Installed the fender emblems.
Old Jun 25, 2010 | 03:04 PM
waldog's Avatar
Aw man, you should let me get the extra unpolished set.
Old Jul 1, 2010 | 03:32 AM
gearhead670's Avatar
IL hows it going?
like the key chain --im putting the the big block chevy radiator in mine right now -lots of fab to strengthen it back up building a lower crossmember for the bottom of the radiator .the hood at the front is only aprox 2 inches wider than the radiator .this means the scoop has to run all the way to the front of the hood .im glad i choose to go the route and put this radiator in the car .measured up the big block and its 32 inches from the back to the dowl on the water pump a very tall order to get it in and the radiator .i have only found one other big block chevy fc and he has a small radiator (its a drag car) mine will be driven on the street and it has to run cool ---make it yourself if ya can is my motto +dare to be different!
Old Jul 10, 2010 | 05:23 AM
CrackHeadMel's Avatar
Learned alot | Alot to go
Wow nice looking pieces. I dont do brass ever and wouldnt have thought it would polish out so nice.
What do you do for work if you dont mind me asking?
Thanks!
Nice looking cnc Nice to know someone else is building one
A friend and myself are almost done (whatever that means) with a our cnc wood router we use for work. Started as a JGRO however im redesigning it for leaner ways, uses rack and pinon and its longer, has a 15x96x6 cutting area
Were getting 780inch's per min feed rates, would go faster but i run out of X travel. Right now its mostly MDF however the gantry is being rebuilt out of aluminium. Aiming for 1000ipm cutting in the Y
Heres an old pic of our pile
-Jacob
Old Jul 12, 2010 | 04:47 AM
levelzero's Avatar
-Jacob
I own a small machine shop. We do a fair bit of custom work, but to fill in the gaps I design/sell car parts.
Thats a unique cutting area. How's the repeatability at those speeds?
Old Jul 12, 2010 | 05:12 AM
Well we have only run it at the 780imp for maby 10min substained and that was without a dial indicator, however we were running it from as close to the limit switch to limit switchs we could and it never tripped one. takes about 6" to ramp upto speed and the same to slow down. We were limited to that short timeframe because the mosfet's on the driver board got hot enough to melt there on solder They now have a massive heatsink and temps peak around 120F
We did however loose some accuracy being we went with such a high available feed rate, about 0.0083s accuracy in X and once Y's done the same there, which granted isnt great, however its roughing out snowboard and ski cores profiles and shapes which are hand sanded after, so its plenty accurate for what we are doing with it. the z axis has 0.00025 accuracy however (not accounting for backlash). If we build another we will go with a microstepping board and servo's so we can get back into tenth's accuracy and still have atleast 700ipm cutting speeds
and some random gloating, heres board #1, no cnc router all hand profiled and shaped
-Jacob
Old Jul 12, 2010 | 02:42 PM
Battle Cat's Avatar
Space cadet
******* sickk!!!
Old Jul 12, 2010 | 02:58 PM
RX7(613)'s Avatar
thats wicked, an awesome job to have.
Old Jul 14, 2010 | 03:46 AM
levelzero's Avatar
Nice board. The router will make the cores alot easier to produce. A router is on my list of machines to get, but I'm looking for something beefy enough to cut 0.5" 6061 at full DOC.
Old Jul 14, 2010 | 07:22 PM
I dont think our motors would allow 1/16th deep cuts with a half inch mill in alu, built for speed not tq.
You looking to build a machine to cut alu or you buying one? Not sure how BC's doing manufacturing wise, however in NH there are piles of deals on pretty new milling and turning machines.
-Jacob
Old Jul 17, 2010 | 01:25 AM
levelzero's Avatar
I may buy another mill and build a router, it mostly depends on when the right deal comes along.
Old Jul 24, 2010 | 07:09 PM
mrmazda's Avatar
Week-ends driver!
Sorry, I guess this is what I should have read before replying in the badge thread.
Very nice work....
If you ever have time to "waste", let me know... maybe we could work on some "RX-7" logos for FD owners!!!!
Old Jul 24, 2010 | 11:25 PM
Alex_n/a's Avatar
this is all i could find for keychains and they sale this for 15 bucks
i would rather have one like yours... if you make another one and get bored of the one you made first just send it to me lol
keep up the good work can't wait to see more of your work must be nice to make pretty much any accessory for your car like infini symbols
Old Jul 25, 2010 | 01:09 AM
levelzero's Avatar
Very nice work....
If there was interest I'd be more then willing to do what I can for other 7 owners.
I will be making a few more, my supplier cut me a deal on the brass so I need to put it to good use.
Old Jan 2, 2012 | 11:40 PM
nemeii's Avatar
oOoo...
Just picked this up, I know this is an old thread but what the heck...
as far as key-chains though, you may take interest.
