air fuel mixture adjustment help
Old Jun 22, 2010 | 02:47 PM
GreenMachine's Avatar
My 1st gen GSL-SE seems to be running quite rich where is the adjustment? Or is computerized or something since it is efi?
Thanks
Old Jun 23, 2010 | 10:52 AM
Aaron Cake's Avatar
Engine, Not Motor
The only built in adjustment for the AF ratio is the idle adjust pot.
If the car is running rich across the board, then there is an issue. Verify that timing is correct, check plugs and wires, check the CLT and then have the injectors serviced. It can also be the AFM but this is harder to check without a known good unit to swap.
Snoopy FD
Dec 8, 2015 01:45 PM
alphawolff
Nov 17, 2015 05:57 PM
86glxNA
Aug 22, 2015 08:54 PM
Wolf_
Aug 11, 2015 04:23 PM
