want to adjust the idle speed, but cannot find the initial set coupler
Old Jun 21, 2010 | 02:23 PM
Ydna's Avatar
I can't find that thing. My '86 NA FC is an euro-spec so the ignition (and much more) is different from the US ones. Does anyone know where I can find it under my hood?
regards, Andreas
Old Jun 21, 2010 | 03:38 PM
jjcobm's Avatar
Are you experienced?
On an S4, the FSM shows it to be a TWO PRONG FEMALE connector right next to the battery. From your picture it seems to be the BLUE connector which has the two prongs. Jumper the two prongs and that will be setting the initial set connector...
In an S5, it would be the SINGLE WIRE green prong jumped to GROUND.
Make sure you power down all accesories (A/C Radio, lights, ect..). When you jumper the initial set connector, you will hear the car idle down a little....
Old Jun 21, 2010 | 04:39 PM
Ydna's Avatar
both wires are already connected to the one pin of the ignition coil.
Old Jun 21, 2010 | 04:54 PM
satch's Avatar
If you cannot find the initial set coupler then you can disconnect the electrical plug to the BAC instead.
matty
Jan 18, 2020 10:39 AM
alphawolff
Nov 17, 2015 05:57 PM
Marty RE
Aug 17, 2015 09:36 AM
