Power FC Rats nest with Power FC.
Old Jun 20, 2010 | 06:53 PM
Azriel_Strife's Avatar
Eff Dee Three Ess
Hey everyone, I know I saw it somewhere but I can't seem to find the thread now. I have installed a powerFC on my single turbo swapped FD. The the rats nest itself has been removed but all the sensors are still plugged into the harness with no vacuum lines going to them.
I was wondering which of these i can unplug from the harness now. And which ones i need to leave. the reason I ask is that my exhaust heat light blinks full time when the rpm's are above 2500rpm. From what I know it;s because a sensor somewhere is either out of spec or not receiving proper signal, I'm assuming it's one of the sensors for my rats nest that isn't plugged into the manifold vacum system.
any help would be greatly appreciated, thanks a lot guys!
Old Jun 20, 2010 | 10:14 PM
arghx's Avatar
rotorhead
Go to etc. --> sensor/sw check in the commander and take a [clear] pic of what you see there
Old Jun 20, 2010 | 10:18 PM
Eff Dee Three Ess
I have no commander. And I don't know anyone that has one.
Do you by chance know which solenoids from the rats nest can be taken out?
Old Jun 20, 2010 | 10:24 PM
arghx's Avatar
rotorhead
You need to get one or just get a Datalogit. You're flying blind on a single turbo FD. This isn't a good idea. If a sensor is highlighted in the left column then your CEL should go off. Or at least, that's how I think it works. The PFC CEL trigger doesn't normally work on USDM cars.
it could also be a noisy knock sensor, but you can't read that without a Commander or Datalogit.
Old Jun 20, 2010 | 10:51 PM
Eff Dee Three Ess
It's going in for a proper tune this week. I'm running with an intentional boost leak to prevent hurting the engine. I just need that light to stop blinking, and I'm pretty sure it's one of the rats nest plugs that are causing it.
according to this: http://www.rotaryresurrection.com/3r...ov_nonseq.html I can just remove all 8 solenoids with the PFC.
The reason the warning system doesn't work on US cars is that they don't have an exhaust overheat light on the dash. Which is what the PFC triggers when there is an issue.
Old Jun 21, 2010 | 09:49 AM
arghx's Avatar
rotorhead
Have you removed your OMP? That might be triggering it. The rat's nest solenoids shouldn't cause it.
Old Jun 21, 2010 | 01:33 PM
Eff Dee Three Ess
No I'm still running the omp. I didn't want the hassle of premix on my daily driver. I would rather avoid paying the shop to locate the problem and fix it since they charge $120 an hour. I'm just going to yank out all the solenoids and hope that does it, if not, then i guess I'll bite the bullet and have them fix it, unless i can find someone in my area with a PFC commander.
streetlegal?
Mar 17, 2022 02:46 PM
Romeoxray7
Power FC Forum
15
Nov 20, 2015 01:38 AM
EfiniGirl
Haltech Forum
Sep 1, 2015 09:31 PM
12abridgeport
Aug 17, 2015 06:28 PM
