Coolant Leak Need some Help
Old Jun 24, 2002 | 05:40 PM
Type RZ's Avatar
Question Coolant Leak Need some Help
well i was driving today and i ran into a friend of mine with a old box styled m3 so we raced and after word when i reached my destination(wich was work) my car start to smoke really bad from the engine bay. so poped the hood and looked around to see where it was leaking, at the same time doing a sniffer test to see what was leaking exactly well after doing a lil sniffer test i knew it was coolant, well i found that it was leaking in the area of the turbo's, but i couldnt never find exactly where it was leaking from but i knew it was in that area of the car. well i get off work and put it on a lift ( i work at a honda dealership im a technician in training) and let the car run but i couldnt find any major leaks anywhere but i did see traces of coolant at the bottom of the car. but i couldnt find any real major coolant leaks so i drove home with no problem but i didnt boost at all. so i have no clue of why i had a huge puff of smoke when i got to work..... sorry for such a long story but when dealing with a mechanical problem u have to know the whole story.
Old Jun 24, 2002 | 06:30 PM
Tim Benton's Avatar
FD title holder since 94
I'd check all the hoses first, , to and from the radiator, looking leaks around the connectors, kinks, then possibly the water lines going to and from the center section of the turbos. It sounds more like as the pressure through the system got high and hot, it puked some coolant on the turbo side which or course hit the hot turbo/heat shields/DP in the area and turned to steam.
See around Atlanta soon,
Tim Benton
Old Jun 24, 2002 | 11:39 PM
Type RZ's Avatar
Wow Tim that actually makes a lot of sense cause now im scared to use my second turbo cause like i think one of my radiator hoses will explode and my car will be in the shop again. hmmmmm well im gonna have to experiment then i guess ill run my car hard later today. well hopefully i wont blow nothing. lol thanks tim we need to meet up some time. i only seen you once at the very first slap show we need meet up again,
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
sinistersam
Sep 13, 2015 07:17 PM
ZaqAtaq
Sep 5, 2015 08:57 PM
