Question about s4 and s5 N/A swaps
Old Jun 17, 2010 | 09:48 PM
rotaryking88's Avatar
Question Question about s4 and s5 N/A swaps
Ok i have a s5 block with a s4 intake mani im trying to get this put into my 88 shell trying to figure out what ecu and harness to use need help with this asap thanks guys
Old Jun 18, 2010 | 12:13 AM
RotaryRocket88's Avatar
Top Down, Boost Up
http://www.rotaryresurrection.com/2n...o_s4_swap.html
Old Jun 19, 2010 | 02:24 AM
zukzilla's Avatar
if useing the s4 stuff then it would require the s4 computer just make sure everything is s4
Old Jun 19, 2010 | 02:25 AM
zukzilla's Avatar
espcally the omp because s5 is eletric and s4 is mechanical
Old Jun 20, 2010 | 12:04 PM
well i know im going to use the s5 block and im trying to get the s5 intake and put the s4 throttle body and more than everything else will be s4 parts how does that sound
Old Jun 22, 2010 | 11:55 AM
Top Down, Boost Up
Did you even read the link I gave you? It sums it all up. Yes, you can use a mix of S4 and S5 parts, but all the electronics need to be from the same series.
Old Jun 27, 2010 | 12:50 PM
midnightbluefc's Avatar
check the link Rotary Rocket gave u! rotaryressurection has plenty of good detailed info...
bb6guy
Old School and Other Rotary
Oct 1, 2018 08:07 AM
hotshot2014
Jul 18, 2017 02:30 PM
RotaryBobby
Aug 29, 2015 10:32 AM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
