Chipped J-spec ECU Question
Old Jun 17, 2010 | 06:00 AM
argh's Avatar
Rotary Fresh
Hello, I drive a 1987 Turbo FC3S and was wondering if a chipped J-spec ECU like PAN SPEED, BLITZ, RE AMEMIYA, and KNIGHT SPROTS will work on U.S. spec FC3S here and if so, how would it run with my set up? and what model # J-spec ECU would i have to run? I am currently running a FMIC, hybrid turbo, boost controller, and Racing Beat FCD. My car runs fine I'm just wondering how much different it would run, if running one of those chipped ECUs. Thanks in advanced.
Old Jun 17, 2010 | 12:34 PM
RotaryRocket88's Avatar
Top Down, Boost Up
Yes, they can work, but you'll be playing the guessing game when it comes to exactly what they changed. Fuel cut removal is pretty standard, but some have timing and fuel changes. There isn't much information available on them. Going with an Rtek ECU would be a better route. You'll know exactly what is being changed, and the prices aren't bad at all. v1.5 - 1.8 are $120-$150. http://www.pocketlogger.com/index.ph...age=1&ecu=S4T2
Old Jun 19, 2010 | 01:07 PM
argh's Avatar
Rotary Fresh
Thanks for the advice man. The R-tek sounds like the perfect way to go.
Old Jun 19, 2010 | 02:23 PM
trooper001's Avatar
The Spanish Stallion
Awesome, thanks for the link RR.
Skeese
65
Mar 28, 2017 03:30 PM
CaptainKRM
14
Aug 26, 2015 09:52 PM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
