RB header question...
Old Jun 14, 2010 | 06:35 PM
3xBlack Vert-top Mike's Avatar
Mike
I ordered Racing Beats True Dual exhaust. To install the header do i need to take off the 5/6 port actuators?
Old Jun 14, 2010 | 08:02 PM
RotaryRocket88's Avatar
Top Down, Boost Up
You might to get enough room to get at the top two nuts on the exhaust manifold.
Old Jun 15, 2010 | 04:00 PM
3vil's Avatar
Mazda Misfit
on my s4 i didn't have to remove the aux port actuators, but it would have given me a lot more room to work. the real problem for me was getting the heat shield off, as the bolts were pretty rusted.
you 91 is an s5 correct? you search here for how to activate the aux ports, but if i remember correctly (which i rarely do these days) the s5 uses the air pump to activate the ports. so removing the exhaust manifold and cats shouldn't effect their operation right?
Old Jun 16, 2010 | 07:32 AM
Mike
yeah the S5 uses the Air pump to activate the ports so i know they will function im just wondering if i need to take them off to install the header....thnks
Old Jun 29, 2010 | 01:22 AM
midnightbluefc's Avatar
its all in how you are with your hands, some people can work around things and get there hands in tight places, when i helped my friend he didn't have to take his aux ports off
Old Jul 1, 2010 | 07:49 PM
Mike
cool thnks...i should be able to do it without having to remove anything
Andrew7dg
Aug 6, 2017 01:41 PM
