Where to buy a wire harness?
Anyone know where I can buy a replacement ECU wiring harness? All the connectors on mine were cracked and broken when I pulled my engine, and I need a replacement for when I put a rebuilt in there. I'm mostly looking for new/like new condition, but I guess anything will work.
Mazda or a junkyard, I don't know of anyone that makes a replacement harness.
The Mazda one is hugely expensive.. Junkyard ones, unless you do the work yourself, chances are some of the connectors will be broken :\ Especially 86-88s, those damn fuel injector and sensor plugs just crack if you look at them funny.
PaulC
PaulC
Originally posted by biorotary
which harness?
the front (from ecu to dash to the whole fron panel) or the engine harness?
which harness?
Bout how much $$$ from the dealer?
the harness is about $450-550usd off the top of my head the number is N370-18-05Z. at this point all he harnesses are hand made so you are paying for labor and the 30% mazdausa takes
mike
mike
mike
mike
Trending Topics
Originally posted by Icemark
Try these guys:
http://www.mazdasurplus.com/Mazda.htm
Usually around $100
Try these guys:
Usually around $100
PaulC
PaulC
1JZ powered
PaulC
PaulC
Originally posted by Ni5mo180SX
Bringing this one back but where did you find these harness's? Every dealer ive called says the parts are archived and its not possible to get them anymore.
If I were to do it again I would just make my own. It's just wires and some plugs. I found New fuel injector plugs are sold at autoparts stores. Most of the plugs could be reused.
Try these guys:
Usually around $100
Try these guys:
Usually around $100
mike
In the case with me, I need a new Front Wire Harness. The cost at www.mazdasurplus.com Is $180 US + surcharge of $50 + shipping.
This, In contrast to $2700 CAN + plus a massive discount of 20% at the dealership.
What should I do?
What should I do?
I'm Installing this behemoth tomorrow. I'm Impressed with this genuine Mazda Front Harness I received from Mazda Surplus. Even before It's Installation.
Thanks Icemark. I wouldn't have known about these guys If you hadn't posted the link.
I saved big bucks...so I guess I kinda owe you one.
I'll post results when I'm done.
