sloppy shifter..
Old Jun 9, 2010 | 09:12 AM
rx421's Avatar
sloppy shifter..
my shifter felt sloppy. I took out the shifter and there was a piece ripped. I just didnt know what part it is. So i dont know what to look for..My shifter was loose. i could move it up and down..
Attached Thumbnails sloppy shifter..-sam_0006.jpg   sloppy shifter..-sam_0007.jpg   sloppy shifter..-sam_0008.jpg   sloppy shifter..-sam_0009.jpg
Old Jun 9, 2010 | 01:58 PM
RotaryRocket88's Avatar
Top Down, Boost Up
The part that is ripped is the inner shifter boot. But it also looks like you're missing both the upper and lower bushings. The bushings cup the "ball" on the shifter, and have small flat springs that press against the underside of the inner boot & the socket in the transmission extension housing.
Mazdatrix carries all 3 of these: http://www.mazdatrix.com/g4.htm
Inner Boot: http://www.mazdatrix.com/getprice.as...m=17-480A-M513
Upper Bushing: http://www.mazdatrix.com/getprice.as...m=17-481A-M508
Lower Bushing: http://www.mazdatrix.com/getprice.as...m=17-4810-M501
Old Jun 9, 2010 | 02:05 PM
rx7421's Avatar
thats alot...i wasnt sure what i was looking at
Old Jun 9, 2010 | 02:08 PM
rx7421's Avatar
this wouldnt have anything to do with my clutch?
Old Jun 9, 2010 | 04:10 PM
Go48's Avatar
No.
Old Jun 9, 2010 | 07:49 PM
bostonspgs's Avatar
Boston Acoustics SPG555's
common wear and tear almost normal as mazdatrix puts it
when you replace all the boots and bushings make sure you drain all that gunk out through the side access plate. spray it clean with brakeleen and replace with 90w gear or rear end oil .you will notice how smooth it is if you do
Old Jun 9, 2010 | 08:02 PM
rx421's Avatar
alright will do!
Rxmfn7
30
Aug 28, 2003 10:46 PM
insomniac
Jun 21, 2003 11:14 AM
RedFD
Feb 25, 2003 11:09 AM
ejmack1
Oct 3, 2002 10:33 PM
romeo
May 24, 2002 11:59 AM
