Megasquirt I need some help here...
Old Jun 7, 2010 | 12:23 AM
a_reyes1014's Avatar
Can someone tell me if this is something relating to tuning or mechanical? My Fuel Ve Table 3 looks rediculous and I'm not sure where to start.
I'm really rich (10.0) around 3000 to 4000 rpm and then really lean around 5000 to 6000 rpm on boost.
File Type: zip
Old Jun 7, 2010 | 10:09 AM
muythaibxr's Avatar
MegaSquirt Mod
What are you using 2 VE tables for?
Ken
Old Jun 7, 2010 | 10:41 AM
To tune one off boost and one on boost. It actually worked before where my afrs were consistent but now for some reason it's not.
Old Jun 8, 2010 | 10:46 AM
muythaibxr's Avatar
MegaSquirt Mod
What changed?
Ken
Old Jun 8, 2010 | 11:34 AM
Well I had a LIM gasket leak which is fixed now. My wastegate spring gave out on me and changed that. That is the only thing that changed.
Old Jun 10, 2010 | 09:25 AM
muythaibxr's Avatar
MegaSquirt Mod
The LIM gasket leak would definitely cause the need to retune a bit, and the wastegate spring could too.
It sounds like you made mechanical changes that will require a retune to me.
Ken
Old Jun 10, 2010 | 09:04 PM
yea I'm in the process of that right now. I just noticed that for the 3000-4000 rpm rich spot was due to my secondaries turning on so I have to tune for that section of the map and also since now all my boost is making it to the motor it seems that my peak torque really shines at around 5000 to 5500 rpm.
Old Jun 10, 2010 | 10:27 PM
Hey Ken another question...is it normal to lower the map where secondaries are turning on? I'm using KPA and RPM to activate the secondaries.
Old Jun 15, 2010 | 04:57 PM
ok started tuning a bit more and seems a little better but it's really rich now as I changed my injector open time to 1.3 ms. also can anyone help with ideas on leaning out the area where my secondaries are coming on.
Old Jun 15, 2010 | 08:11 PM
muythaibxr's Avatar
MegaSquirt Mod
I typically use the table-based staging anymore, so I don't get any oddity when the secondaries come on.
If you post your staging settings that might help me figure out why it's going rich when they come on.
Ken
Old Jun 15, 2010 | 11:49 PM
here's the msq:
File Type: zip
wstrohm
3rd Gen General Discussion
40
Apr 16, 2016 08:23 AM
Jan 11, 2016 04:08 PM
GTR
Dec 25, 2002 12:32 AM
MaxSpoolin
Jul 12, 2002 06:34 PM
rob1out
Mar 2, 2002 02:24 PM
