Rtek Forum Discuss the Rtek 2.0 and other Rtek ECU's
Rtek adjustments due to afm
Old Jun 6, 2010 | 12:59 AM
hiroichi1515's Avatar
With the rtek 2.1, using the map table rather than the stock load vs rpm and fuel correction table, what adjustments does the ecu make due to readings from the afm? I understand with a stock ecu, but if I set my own tables, does the ecu still make adjustments from the afm? I am using s4 N333 & n318 components.
Old Jun 6, 2010 | 04:11 AM
solareon's Avatar
the afm is used for the initial calculation and then the map vs rpm table is used to apply a correction to it.
R.O.D
34
Jan 6, 2016 12:09 AM
R.O.D
Rtek Forum
Sep 23, 2015 01:15 AM
Ernstudet22
Sep 14, 2015 09:19 PM
