Other Engine Conversions - non V-8 Discussion of non-rotary engines, exc V-8's, in a car originally powered by a Rotary Engine.
93 rx7 2JZ turbo/r154 widebody
Old Jun 5, 2010 | 08:05 PM
protunedperformance's Avatar
i have been delaying putting up a build thread for long enough. i have been building and working for about 2 years. ill start with the early pics and eventually get to the good stuff.
this is what she looked like when i got her
the old engine. bye bye rotary
the engine first arrived, aristo 2j and an sr20. the sr20 seems like half the size.
fully torn down and heading to the machine shop
Old Jun 5, 2010 | 08:07 PM
got rid of where it used to be plastic and filled it with metal.
primed to prevent rust for the time being.
where all my fuse boxes are going to be located
had to remove a part of the fire wall in order to get the engine to fit
this is the front support where basically every thing bolts up to. took the old flimsy one and replaced it with 1/8 inch angle iron.
Old Jun 6, 2010 | 12:30 AM
fstbckgt's Avatar
Barrel Roll
lookin very good, subscribed
Old Jun 6, 2010 | 01:04 PM
xerospeed's Avatar
CHECK ENGINE
good stuff so far, lookin forward to more progress
Old Jun 7, 2010 | 04:01 PM
TrboSpdAnt's Avatar
Boost makes cars smile.
Subscribed; PM sent.
Old Jun 8, 2010 | 09:28 PM
built a mini paint booth just for knocking out the engine bay.
almost ready for paint. sanded and sanded like u would never believe. ended up redoing all the seam sealer . it looked like someone just threw it on from across the room. i took me about 2 days to get it looking good. u can see it in some of the previous pics.
and all done
Old Jun 12, 2010 | 09:07 PM
heres the internals. carrillo rods, cp pistons, upgraded wrist pins, arp main studs
this the engine when it originally came back
wasnt happy with the color so i did this
Old Jun 12, 2010 | 09:08 PM
got the head back, brian crower 1mm over valves and springs and full port and polish, stock cams for now but that will change.
Old Jun 12, 2010 | 09:23 PM
Viking War Hammer's Avatar
*** Bless The USA
all that work and you painted over the shock bolts?
Old Jun 13, 2010 | 02:40 AM
TrboSpdAnt's Avatar
God, that's HOT.
Old Jun 16, 2010 | 09:24 PM
Oscar8404's Avatar
What subframe is that??
Old Jun 17, 2010 | 12:41 PM
the subframe is from tech 2 motorsports
Old Jun 17, 2010 | 01:41 PM
ByeByeSti's Avatar
so youve got an fd that your putting the 2jz in, and a kouki which your putting the s14 sr into?? im jealous. i miss my s14's. and my damn rb'd FD isnt done yet
Old Jun 21, 2010 | 10:19 AM
fully assembled short block
Old Jun 21, 2010 | 10:20 AM
twin disk clutch masters clutch.
and the r154 transmission with upgraded parts and shifter extension.
heres the upgraded parts
Old Jun 21, 2010 | 10:21 AM
tein coilovers. paid 550 shipped for these. it was such a good deal it was hard to pass up. not my first cice for coilovers but the will get the job done.
Old Jun 25, 2010 | 04:00 PM
got the head mounted up
got the accessories mounted on the engine
this is back when i mounted up the engine before i took it out to paint it.
Old Jun 25, 2010 | 07:48 PM
ProjectD's Avatar
I'm on a Boat!
Nice build
More pix please
Old Jun 28, 2010 | 05:16 PM
and finally im getting to the wide body part of this build.
Heres the rims and tires...
12 inch work vs-xx
A nice set of 335's for the rear and some 235's for the front
Old Jun 28, 2010 | 05:17 PM
and heres the wide body, well just the rear for now...not sure if im gonna do the front.
the first cut
a little mock up action
and some tack welded rear custome fenders.
Old Jun 28, 2010 | 05:18 PM
Old Jun 28, 2010 | 05:19 PM
pics of the rear fenders primed and ready for paint. the wheels are not aligned and the height of the car is not set, still gotta get to that. sorry for the bad lighting.
Old Jun 28, 2010 | 05:40 PM
bhop's Avatar
Semi P-PORT
Pretty sick project.
Old Jul 19, 2010 | 02:10 AM
FL
Old Jul 19, 2010 | 03:47 AM
KKMpunkrock2011's Avatar
dorito powered
eees so shinee
