help with a few issues
Old Jun 23, 2002 | 10:39 AM
ncmn's Avatar
greetings,
just looking for comments on three things.
1) for those w/a header, how hot did it ever get -red hot? after getting mine on, and just driving for 10km, i popped the hood and checked out the engine situation. the shiny header is not so shiny anymore. and it is hot!
2) that got me wondering if all that heat trapped under the hood can damage anything during long drives. would it be a good idea to find a way to shield/deflect it? should i care? what might have been done by others here?
3) and finally, besides a failed tach, what are other observable signs of a bad trailing ignitor (vs. trailing coil)?
much appreciation,
norman ng
Old Jun 23, 2002 | 10:53 AM
jeremy's Avatar
male stripper
if the heat concerns you, get a header blanket (not the wrap unless you want to replace the header soon) or send it off to be coated. can't remember off the top of my head who does the coating though.
Old Jun 23, 2002 | 02:36 PM
SilverRocket's Avatar
EliteHardcoreCannuckSquad
The header does get hot, but if you see it glowing red at night that isn't good, it means you're running lean for some reason. Under normal temperatures the header will, over time, get less shiny, I wouldn't worry about it.
I have a heat shield for my intake manifold as part of my Dellorto setup - if you wanted to, I'm sure you could always fashion your own somehow. Again though, I wouldn't worry about it too much.
Old Jun 23, 2002 | 11:16 PM
ncmn's Avatar
no no, not red hot -that's my extreme wondering. i just noticed that it got tarnished quickly. when i touched it, it reminded me of when one grabs and releases a pan handle of a pan that's been sitting on the fire too long. i'm just looking for re-assurance that i'm not going to fry an expensive engine component when i go on road trips.
i'm actually interested in an answer to the ignitor question. my tach does not work but besides that how else can one tell if the ignitor is bad w/o actually pulling it off and testing it?
thanks
norman ng
Old Jun 23, 2002 | 11:23 PM
coldy13's Avatar
Yeah, shutup kid.
i dont know any other way, the test is VERY simple and took me 5 mins at the most, just do it to be sure if its the problem or not.
rgordon1979
40
Mar 15, 2022 12:04 PM
Shainiac
Jul 17, 2019 02:20 PM
Bauer778
Nov 4, 2015 04:42 PM
betes
Sep 27, 2015 08:25 AM
Steven_McKinley
Sep 5, 2015 10:48 AM
