Removing a Vac Hose on BAC HELP
Old May 25, 2010 | 03:36 PM
RobZeroits's Avatar
RPM in my blood!
Question Removing a Vac Hose on BAC HELP
So I got my block off plates for my ACV and EGR. I want to put a bov where the bottom vac hose connects in between the turbo and intercooler. I know you can block it off but I'm just making sure I can block off that line without problems.
FYI I have a 88 turboII, Thank you!
-Rob
Old May 25, 2010 | 08:25 PM
RotaryRocket88's Avatar
Top Down, Boost Up
You can't block it off without problems. Disabling or removing the BAC will cause idle to suffer. The BAC stabilizes idle under electrical & mechanical load.
24seven_dada
20
Nov 10, 2018 12:03 PM
ZacMan
Sep 19, 2015 09:20 PM
NotMrButts
23
Sep 15, 2015 09:46 PM
