Help me decide on getting an rx-7 please!!!!
Old May 25, 2010 | 01:36 AM
240sxdrifter17's Avatar
FL Help me decide on getting an rx-7 please!!!!
hay whats up guys i joined in hopes of getting a 1988 fc.....it has
Turbo 2 Swap from jdm of miami...has an upgraded 20g turbo.
Turbo 2 Trans/Drive Shaft/LSD Diff and Axles
Has New fuel pump and sending unit
Turbo 2 Wing and Hood
S5 Tail lights
Large Mrount Mount
hks knock off BOV
Manual Boost Controoler
3in Turbo back with no muffeler
Halo Head lights
Smoked out marker lights
Mint interior
Working sunroof
ACT 4Puck Clutch
now i own a 92 240sx ka24det full drift car setup and i have no knowledge about rotary..what i want to know is if i trade straight up for this car will it be reliable..how do they run..is there anything i should know, are parts expensive, will the motor blow on me,how much power will i make on the 20g and what is stock boost...
Old May 26, 2010 | 10:34 PM
farberio's Avatar
NASA-MW ST4
Do your research before making a trade. If you know nothing about rotaries getting one so extensively modded is probably not the best idea.
Old May 27, 2010 | 01:21 PM
thanks for failing to answer any of the questions above.....anyone???
Old May 27, 2010 | 02:29 PM
farberio's Avatar
NASA-MW ST4
Depends on how its set up, if the modder is competent and most importantly the tune.
how do they run..
Lots, the search feature at rx7club.com is very handy.
Depends on what you buy, there's cheap parts, expensive parts and really expensive parts. Rebuilding the engine is usually more then a piston engine.
No fuel mods listed, so I am guessing 200ish at the wheels.
Old May 27, 2010 | 02:40 PM
r4itei's Avatar
since you need to ask and you havent done research...then it wont be reliable if you dont maintain it.
how do they run? using doritos... but seriously, you need to do research, ive been researching these cars for about a year and a half, still learning something new all the time. i wanted to get one last summer but after reading the stickies and threads i found out i wasnt ready for a car like this. this summer i think i will be ready.
the motor life is dependent on how well you maintain it, watching out for overboost, running lean, etc. like i said, search is your friend.
http://aaroncake.net/RX-7/
http://rotaryresurrection.com
theres a bunch more to help get you started. rebuilds are around $2000. read up on as much as you can. threads, stickies, all very useful.
Old May 27, 2010 | 02:41 PM
Chris_V's Avatar
=o
The 2nd gen faq should answer some if not most of your questions. Get a compression check on the engine then report back. You really can't tell how much life is left before the engine goes pop based on mileage.
Old May 27, 2010 | 02:46 PM
r4itei's Avatar
chris, since you live in cali, is emissions a PITA for your 7?
Old May 28, 2010 | 04:07 AM
Chris_V's Avatar
=o
I'll be smogging my 7 for the first time this year. It's been almost 2 years and california requires the seller to smog the car for the buyer before purchase. My 7 just has a downpipe and low miles (44k) so passing smog shouldn't be that hard. Any more upgrades and my chances of passing would be greatly decreased.
My other ''older'' cars that aren't in the greatest shape always have a tough time passing.
The1Sun
Sep 15, 2015 04:45 PM
t-von
Sep 10, 2015 01:56 PM
The1Sun
Sep 7, 2015 10:21 PM
