differential questions
Old May 21, 2010 | 02:27 AM
joemaddox's Avatar
From: Philomath Oregon.The five whole blocks of it!
I am getting a 84 GSL tomarrow from a guy...the guys car has a 84 GSL rear end with 4:88 gearing. And i want to know if i can put those gears in my 85 GSLSE rear end or are the axles bigger? Is there a way to mix and match??
Old May 22, 2010 | 11:25 AM
installer67's Avatar
Dreamin of drivin my 7!
Joe, I did a search for ya in the first gen. section for "diff swap" and the answer to your question is YES, you can swap them. The axle sizes are the same on all the 83.5 to 85 models. The flange is different on some (some with through bolts, some not), but the rest is the same.
Old May 22, 2010 | 11:35 AM
blwfly's Avatar
kiwi from downunder..
if the flange on the diff has threads its the small axel diff
through bolts and its bigger axels.
what i have been told.
Old May 22, 2010 | 01:20 PM
jinxed4dub's Avatar
I'm pretty sure flange size is same from 83-85, and the large axles are 84-85. but gsl and gsl-se axles are the same diamiter but differant lenghts. but gearing is same on both so you should be good.
Old May 22, 2010 | 02:12 PM
joemaddox's Avatar
^ are they different lenghts becuase of that larger (thicker) brakes?
Thanks everyone! i picked up the car yesterday and i will ripping the rear end out today to see if what i was told is even true
_Tones_
May 25, 2021 05:37 AM
kkev.7788
West RX-7 Forum
Sep 2, 2015 02:13 AM
