Rtek Forum Discuss the Rtek 2.0 and other Rtek ECU's
Rtek "unsupported parameter id 253" and "unexpected table size"
Old May 20, 2010 | 09:56 PM
CWynn5's Avatar
I get these two errors. I bought the rtek last month and it is the 2.1 version on a s4 turbo.
When in the fuel and timing maps, I will frequently get the error message "unexpected table size." Also, I get the message "unsupported parameter id 253" when trying to open my log files.
It took me about 10 hours total to input my timing maps. The computer would hang for 15 seconds or so randomly after getting the "unexpected table size" message. This would sometimes happen every other cell I would work on. Also, the ecu configuration would randomly reset to the stock values, leaving me to re-input everything once again.
I contacted DTI about 3 weeks ago about the log problem. I believe they are still working on it. I am leaning towards a problem with logging the wideband o2 sensor through the var res input. However, I don't have a problem reading logs on the palm or viewing the wideband on the palm. I am really baffled.
Has anyone else experienced these problems with rtek? Hopefully I can figure these
Old May 20, 2010 | 11:00 PM
66 impala's Avatar
I had the problem with the unexpected table size when entering values. It would **** me off so bad. It would only do it every now and then but when i cycled the key it would stop.
Old May 21, 2010 | 10:16 AM
turbo2ltr's Avatar
The unsupported param error we are still working on. Unfortunately the viewer was written by a customer so we are at his mercy. He is aware of the issue and is working on it.
As for the unexpected table size, sounds like a communication problem. I believe you have an open help ticket for both these issues so replies will be there.
Old May 21, 2010 | 01:30 PM
WingsofWar's Avatar
The Firestarter
I use to have that table size issue when entering values also. I just figured it was my palm because the sync cable was loosing contact on the device. So i switched to a newer palm and i haven't had that issue since then.
I think Turbo2ltr is right about it being a communication error.
Old Jun 1, 2010 | 04:39 PM
turbo2ltr's Avatar
Please download the latest version of the viewer from
http://digitaltuning.com/index.php?pid=utilities
The new version is 2.03G dated May 30,2010 which should fix the problem. Sorry for the delay.
Old Jun 2, 2010 | 07:49 PM
CWynn5's Avatar
This fixed the problem! Thank you so much! I will be posting logs momentarily, hopefully you guys can help me out.
Old Jul 23, 2010 | 10:15 PM
rx7 SE's Avatar
Enthusiast
Hmm, I'm getting the same error. I have the PLviewer 2.05g dated May 30, 2010. Any suggestions?
Old Jul 24, 2010 | 07:07 AM
turbo2ltr's Avatar
are you trying to open an old log or are you running old pocketlogger software?
Old Jul 24, 2010 | 10:55 AM
rx7 SE's Avatar
Enthusiast
I was changing my timing maps this morning and it would keep saying that the there was an "unexpected table size" if I went to fast. I got it to go away by just waiting 3 seconds in between changing each cell. Took a long time, but worked in the end. Even still, the next time I go to tune it, it would be nice to be able to go at my own rate and not have to wait for the software. How do I check to see if I have the latest software?
Old Aug 3, 2010 | 07:08 PM
rx7 SE's Avatar
Enthusiast
Still having this problem, even with the fuel maps. It doesn't happen until the screen has to shuffle to the next row or column in the table view.
I can take a vid and post it if that helps at all?
Old Aug 4, 2010 | 10:09 AM
turbo2ltr's Avatar
yes it would help. thanks.
Old Aug 4, 2010 | 09:21 PM
rx7 SE's Avatar
Enthusiast
Having troubles uploading the vid. It's 26 MB, can you just pm your email and I'll email it to you?
Old Aug 4, 2010 | 09:32 PM
turbo2ltr's Avatar
Dont email it direct or you'll take my server down. lol.
try https://www.yousendit.com/ and email it to "support" at you know where .com
Old Aug 5, 2010 | 01:02 AM
turbo2ltr's Avatar
Is that an M515 PDA?
There is something very wrong with it. I've never seen it move so slow navigating the table like that. Does anyone else's Palm do the same thing? That would drive me nuts.
www.pocketlogger.com/xd9/rtek.mov
See around 0:13, and again at 1:25. how slow the table scrolls. Even on the slowest palm, a M100, the tables should slide right over very quickly.
Do you have anything else installed on the Palm? Any hacks?
I know this isn't the problem you are concerned about, but I have a feeling it might be related.
Old Aug 5, 2010 | 07:46 AM
rx7 SE's Avatar
Enthusiast
...I'm kinda glad you're surprised too because I found it frustrating at how slow this software or palm was. It's an m515 I got off ebay for $35, maybe I'm getting what I paid for?
I pretty much opened it up out of the box, charged it, then downloaded the pocketlogger software. Nothing else.
Old Aug 5, 2010 | 11:16 AM
Nick_d_TII's Avatar
I'm using a palm Vx that I got for $5 off CL and its been working great... sorry man. Good Luck.
Old Aug 5, 2010 | 04:23 PM
rx7 SE's Avatar
Enthusiast
hmm...would anyone mind posting (or directing me to) a video of how fast this software is supposed to move?
Old Aug 5, 2010 | 04:37 PM
turbo2ltr's Avatar
http://www.youtube.com/watch?v=4DstsOtJN3E
2:25
This is probably a little faster than some of the slower Palms, but not much.
Old Aug 5, 2010 | 10:26 PM
rx7 SE's Avatar
Enthusiast
What do you suggest I do? Get a different palm or reinstall new/different version of software? Something definitely isn't right with mine compared to that vid.
Old Aug 6, 2010 | 10:30 AM
turbo2ltr's Avatar
I would probably try a full factory reset and reinstall.
Follow the directions for a hard reset and select "erase all data"
http://www.digitaltuning.com/?pid=faq_pda_reset
(note that this erases anything you have saved on the Palm. If you hotsync before the reset, your maps and logs will be saved to your PC. If it's something you want to keep, you should copy them out of the backup directory and store them someplace else on your computer before proceeding. They aren't safe in the backup directory)
After the Palm boots, hotsync. Your PC will ask you to select a user from the list or create a new one. DO NOT select the old one from the list, create a new one.
Once that is complete, install the Rtek software again (making sure you select the new username in the Palm Install Tool) and hotsync again. See if it helps.
Old Sep 28, 2010 | 05:19 PM
rx7 SE's Avatar
Enthusiast
Finally got around to doing the hard reset on my palm. Same problem, looking for a new palm pilot so I can tune this thing a little quicker. Is there anything else I can try doing?
Old Oct 15, 2010 | 11:06 PM
rx7 SE's Avatar
Enthusiast
Purchased a Tungsten T2 off ebay for $25 bucks. Much faster
Old Oct 21, 2010 | 01:59 PM
87-Rexxer-GXL's Avatar
Rtek..... When are you gonna learn, Complete stand alone or nothing haha.
Old Oct 21, 2010 | 02:29 PM
turbo2ltr's Avatar
'or nothin' as in if you go stanalone you'll have nothing left for anything else?
Old Oct 21, 2010 | 02:31 PM
Nick_d_TII's Avatar
^^ coming from someone who has a STOCK 03 Subaru and a Rx-7 'Sport'... LOL. GTFO
