Which kits are plug N play?
Old May 20, 2010 | 09:54 PM
GoRacer's Avatar
Speed Mach Go Go Go
No cutting, splicing, soldering of wires and finding my own connectors and water tank. I'm looking for everything included with instrcutions. Can someone tell me wheich kits to look at?
Old May 20, 2010 | 10:49 PM
SirCygnus's Avatar
whats going on?
learn how to cut, solder and splice????
Old May 21, 2010 | 06:58 PM
GoRacer's Avatar
Speed Mach Go Go Go
^ booo!
ok, I can solder and heat shrink, but i'd prefer a cleaner setup. So I guess which kits are complete (pump, hoses, nozzles, tank, etc)?
I've gone to alky, Rice and coolmist (I think it is) and none of them show what each kit looks like, what's included or anything. Basically a main page and a link to a forum.
Old May 21, 2010 | 07:54 PM
Hotwheelz's Avatar
Who say's i need a Van
Snow or AEM
Old May 21, 2010 | 08:49 PM
proz07's Avatar
looking for 82-83 corolla
http://www.aquamist.co.uk/vbulletin/...ead.php?t=1623
and going through howerton engeneering they will get you a kit and thier tank to suit your needs but there is NO kit that is easily plug and play this one has bare minimum cut/splice for ease to the end user. and one of the best kits out there short of full control from your aftermarket EMS.
z
infact after power and ground only 3 wires to tap into
1. DIM
2/3. INJECTOR POS/NEG
Old May 21, 2010 | 10:47 PM
GoRacer's Avatar
Speed Mach Go Go Go
Thanks guys - I like the Snow Max and the Aquamist HFS-3.
The Aquamist seemed to be plug n play untill I read the forum which looks like I may need the summer add on module. I can't find the price for the kit itself though.
Old May 22, 2010 | 10:08 AM
proz07's Avatar
on the HFS-3 you do not need the summer you can just tap into the secondary inj signal then turn down the inj duty cycle turn on time and itll inj when the secondaries come on line matching inj duty cycle.... or the summer but you can actually run the summer without even using the hfs-3 for a even cheaper setup without gauge just match the inj to how much you want to use and the summer will drive the HSV to equal inj duty cycle.
for pricing go to howerton engeneerings website for ordering in the US.
z
on the summer you can only get that directly from aquamist FYI built to order.
whizzybang
Naturally Aspirated Performance Forum
21
Feb 10, 2017 12:08 PM
TheAsset
Sep 5, 2015 04:36 PM
