Megasquirt Lead coil not firing
Old May 3, 2010 | 10:45 AM
Defiantone's Avatar
I have a ms1 v3 on an S5 6 port turbo. The car was running fine a week ago. Now the trailing coil isnt igniting but the trail is igniting. I swapped out the coil into another car and the other car fired fine So it isnt the coil. I was wondering if anyone had any ideas. I just let it sit a week while I waited and changed the throttle cable.
Old May 3, 2010 | 10:57 AM
a_reyes1014's Avatar
Check the transistor that fires the leading. I think it's the one that connects to D14. I had this go out on me and swapped out like 3 different coilpacks thinking it was the coilpacks. Give that a try.
Old May 3, 2010 | 10:58 AM
muythaibxr's Avatar
MegaSquirt Mod
Check the pullup resistor on D14, and the transistor that turns on that LED.
Ken
Old May 3, 2010 | 11:05 AM
Defiantone's Avatar
I am an idiot its the trailing not firing not the lead :s
Old May 3, 2010 | 03:36 PM
toplessFC3Sman's Avatar
with the MS1 code, the trailing doesn't fire below 700ish RPM IIRC... make sure you're spinning faster than this
Old May 4, 2010 | 04:34 PM
muythaibxr's Avatar
MegaSquirt Mod
Ahh yeah, forgot about that, it's been a couple years since I used MS1!
Ken
windom
Sep 11, 2015 04:48 AM
SakeBomb Garage
Vendor Classifieds
Sep 7, 2015 03:44 PM
SakeBomb Garage
SakeBomb Garage
Sep 7, 2015 03:32 PM
