12at + msd sci. box = help......
Old Apr 30, 2010 | 11:52 AM
Rotospeed's Avatar
its a 85 gs stock 12a, with a s4 turbo, locked dizzy and a holley 600.
i had the dlidfis on the car befor but removed it when installing the turbo set up, so with the stock ign. i time it at 10-0 and it runs good but when i hook up the msd box the timming is way off and i need to turn the dizzy 1 tooth to set it at 10. thats ok but then the closest i can get the timing split is about 25 deg. and that is the problem.
the msd set up is a sci box using the purple and green wires with a sheilded cable to a gutted igniter. its got 2 stock coils for the direct fire.
so what can i do to fix this timming? or if its not going to work with this box ill just go back to the dlidfs set up..... but i would like to have the msd working.
thanks for eney help.
and ill get some pics up in a bit.
Old Apr 30, 2010 | 04:24 PM
j9fd3s's Avatar
Community Builder
if the timing changes with and without the MSD, something is backwards.
Old Apr 30, 2010 | 07:51 PM
bad 83's Avatar
PSHH! PSHH! HEAR ME NOW?
Are you using the MSD to trigger the leading and the trailing, or what? I am running a MSD 6A on the leading with a second gen leading coil. No issues.
Old Apr 30, 2010 | 08:35 PM
Rotospeed's Avatar
as in......pick up wires or what?? im not sure what to check.
trailing is stock. leading is gutted igniter to msd box to 2 fb coils to plugs.
if the purple and green wires are switched would that do it??
84stock's Avatar
I run the mazdaspeed wiring diagram for my msd, timing didn't change at all. You have something drastically wrong. Did you boost prep your holley and run a rrfpr.
Old Apr 30, 2010 | 08:42 PM
Rotospeed's Avatar
yes its boost preped and ive got a rrfpr for a carb.
ill start going over the wireing again.
has no one els had this problem
Old Apr 30, 2010 | 08:43 PM
84stock's Avatar
Read one of your old posts where you changed the exhaust. Nice looking setup.
Old Apr 30, 2010 | 09:01 PM
j9fd3s's Avatar
Community Builder
purple and green would do it, um if the wires were crossed in the gutted ignitor that would do it.
Old Apr 30, 2010 | 10:52 PM
Rotospeed's Avatar
crossed wires in the igniter it was. fixed it and the timming is good, once i finnish up a couple of other things in the next few days i can finish tunning it.
THANK YOU GUYS !!!
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
gxl90rx7
Haltech Forum
Sep 14, 2015 03:09 PM
