Carburetor Leaking out ontop the engine
Old Apr 28, 2010 | 10:27 PM
79RX7IA's Avatar
Exclamation Carburetor Leaking out ontop the engine
My carburetor is leaking gas out on top of my engine. It appears to be coming from this piece that is square shaped. the throttle piece touches it somehow because when you press the gas one of the pieces move and then gas drips out.. I will upload a picture soon. Is this a simple gasket or ring I can replace?
Old Apr 29, 2010 | 10:34 AM
84 GSL's Avatar
It's supposed to do that.
If I understand your statement correctly, I had the exact same problem on my car earlier. It was the diaphragm pump, and it will cause the car to be very hard to start unless you add gas to the carb. It can be replaced without rebuilding the entire carb, and if the car runs fine once cranked I would recommend just replacing it and not building the whole carb.
Old Apr 29, 2010 | 11:30 AM
rxtasy3's Avatar
it's call the accelerator pump so u know what to ask for if u replace it.
Old Apr 29, 2010 | 03:51 PM
Saks_RX7's Avatar
It could be the lower seal, near where the float is. I had an old snowblower (bad example but anyways) that kept leaking gas because that seal was gone.
Old Apr 30, 2010 | 02:55 AM
mazdaverx713b's Avatar
Have RX-7, will restore
the accelerator pump diaphram is faulty and needs replaced. order a carb rebuild kit and do it the proper way.
Th0m4s
Feb 26, 2019 02:04 AM
Microtech
30
Apr 23, 2016 06:37 PM
86glxNA
Aug 22, 2015 08:54 PM
