No Start after carb rebuild
Old Apr 26, 2010 | 01:51 PM
stephp's Avatar
Get Excided & Make Things
MS No Start after carb rebuild
OK, so I decided to rebuild the carb that came with my 'new' engine since I could not get the original one to work after a rebuild.
The carb and engine are both modified. The engine is street ported and the carb is a stripped Nikki (non-sterling). Rats nest is also removed. Everything appears to be connected correctly and carb was an easy rebuild (the second one is always easier i guess). My problem is I still cant get the thing to run. If I pump the accelerator a few time so that the accelerator pump squirts some gas in or if I just pour a little down the carb's throat, it will start right up. But, it dies as soon as the gas runs out. The carb does not seem to be feeding gas at all. Both bowls are at half on the site glasses and I can see gas feeding if I use my air compressor to blow air down the card. However if I look down the carb while I have someone try to start it, it looks dry?
Any ides?
Thanks in advance.
Step
Old Apr 26, 2010 | 02:10 PM
Bearzah's Avatar
Me Wantee Da' Boostee
vacuum leak.... sounds like it's leaning out and dying once the squirt of fuel runs out.
Th0m4s
Feb 26, 2019 02:04 AM
Jun 26, 2016 10:21 AM
1993fd3sracer1
29
Oct 13, 2015 01:57 PM
1993fd3sracer1
20
Sep 7, 2015 11:50 AM
