Does a 90 vert stock come with Redline buzzer
Old Apr 23, 2010 | 03:24 PM
juicedvert's Avatar
Brap Brap Brap
NC Does a 90 vert stock come with Redline buzzer
I just bought a 90 rx7 vert. Anyway i keep reading about the redline buzzer. Did my car come with one? If not can i install one off another rx7?
Old Apr 23, 2010 | 07:16 PM
RotaryRocket88's Avatar
Top Down, Boost Up
All FCs have the buzzer.
Old Apr 24, 2010 | 11:20 AM
juicedvert's Avatar
Brap Brap Brap
NC now i cant find it
Do you know where its located? Mine hasn't worked since i bought the car
Old Apr 24, 2010 | 11:29 AM
Erix7rew's Avatar
It is on the cluster mainboard. It's weld on the mainboard!
Eric
Old Apr 24, 2010 | 12:13 PM
juicedvert's Avatar
Brap Brap Brap
oh great... Is it just a speaker thats solderd on?
Old Apr 24, 2010 | 12:51 PM
juicedvert's Avatar
Brap Brap Brap
Ok so I know exactly where it is. What does it look like? Can it be solderd with a normal soder gun? I ask because I've never don't anything like this before
Old Apr 24, 2010 | 03:09 PM
Cole509's Avatar
Take it to 7-8k RPM and find out :p
Old Apr 24, 2010 | 03:39 PM
Erix7rew's Avatar
Yes you can use a regular solder gun but it easier to change the cluster. Anyway you need another buzzer to swap so you need to find another cluster.
If you want to keep your speedo for keep the millage, take the other cluster you need to buy and swap your speedo in it. It's just screw in so no need to solder.
Eric
Old Apr 25, 2010 | 10:10 AM
Aaron Cake's Avatar
Engine, Not Motor
I'd argue it's not easier to change the cluster for a 2 minute soldering job. You can use almost any 12V buzzer, but it won't have the same noise as the original FC buzzer.
If you have never soldered before, this may help:
http://www.aaroncake.net/electronics/solder.htm
Old Apr 25, 2010 | 07:15 PM
MR. ROTARY's Avatar
i guess my buzzer is not working also....oh well lol....then again my 91 vert is automatic lol
Old Apr 26, 2010 | 12:06 PM
juicedvert's Avatar
Brap Brap Brap
Well I'm going to take it apart today when I get home and see if its just cracked soder or a blown buzzer
Old Apr 26, 2010 | 12:11 PM
juicedvert's Avatar
Brap Brap Brap
Ill let you guys know what I find. Thanks again for all your help
Old Apr 26, 2010 | 08:32 PM
juicedvert's Avatar
Brap Brap Brap
Well I found a speaker but it was white and on the left side of the cluster. I thought it was closer twards the middle. But I saw it without having to take the board off. Is this the correct speaker
Old Jun 7, 2010 | 10:09 AM
juicedvert's Avatar
Brap Brap Brap
Hey guys. I never got it fixed. I have another question. I found a little square white speaker twards the left side of the cluster. Its soldered on at 4 points
Old Jun 7, 2010 | 12:31 PM
juicedvert's Avatar
Brap Brap Brap
need help with buzzer
Hey guys. I drive a 90 vert. My buzzer never worked since I bought the car. I tried to take out the cluster but wasn't sure how to remove the connectors on the back. I wiggled it out far enought to see a little white speaker on the left of the cluster. It was also solderd at 4 points. I wanna know if that's the buzzer. If it is can u buy a replacement fc buzzer or do I have to just buy a universal buzzer? If that isn't it how do you remove the connectors on the back of the cluster.
Old Jun 9, 2010 | 08:42 AM
Aaron Cake's Avatar
Engine, Not Motor
The little white speaker is the buzzer. I don't know where you can get an exact replacement off hand, but any 12V buzzer will work. Or you can salvage one from another RX-7 cluster.
Old Jun 9, 2010 | 09:17 PM
13bgt35r's Avatar
or just leave it off, its annoying!
Old Jun 10, 2010 | 09:15 AM
Aaron Cake's Avatar
Engine, Not Motor
It may be annoying, but that buzzer is also the low coolant and low oil warning.
Old Jun 10, 2010 | 02:28 PM
juicedvert's Avatar
Brap Brap Brap
just wanted to say thanks
Hey everyone I just wanted to say thanks for all your help! I don't know if I could have done it without you guys. And the buzzer I bought from radioshack is very similar to the stock sound and was only 3 dollars. Good stuff. Well thanks again
Old Jun 10, 2010 | 02:56 PM
Vierte's Avatar
annoying?
love the buzzer...
embrace the buzzer...
let it cry i need oil! (or try not to let it cry)
let it warn you of impending cooked coolant seals...
let it guide you through tire destroying sideways pavement assaults...
the buzzer is there to prolong your rx7 experience, use it.
LMBTG
Sep 2, 2015 07:01 PM
DaleJK
Aug 31, 2015 10:19 AM
