Introduce yourself New members post about yourself here...
new with 86 rx7 gxl
Old Apr 22, 2010 | 11:04 PM
thatonedude's Avatar
new with 86 rx7 gxl
hello im new to this website i have had my 86 mazda rx7 gxl non turbo since about november. note it is my first car ever being that im only twenty. when i bought the car it wasnt running, i had to fix a fuel line and replace the master and slave cylinders for the clutch to finally have it running right. i still havent passed smog but i have made huge improvements. at first it was just the emissions that didnt pass but when i just recently went to try and smog it i was told that the only thing wrong with it now is the EGR valve. I cant find a egr valve from that car anywhere, and im not sure that a turbo version would work on it. like i said im pretty new when it comes to cars so any advice would be great. thanks!
Old Apr 23, 2010 | 11:02 AM
RotaryRocket88's Avatar
Top Down, Boost Up
Welcome to the site. The new member and 2nd gen technical sections should prove to have a lot of the answers you're looking for.
The EGR valve is located underneath the upper intake manifold (UIM). A turbo version will work, but you may have to cut the little heatshield off of it. The flange and functionality are the same. Good luck.
Old Apr 26, 2010 | 03:49 PM
dat_kid's Avatar
Have any pictures of your car?
Im faster
Aug 19, 2015 02:57 PM
BucketsAllDay
Aug 19, 2015 03:41 AM
