Canadian Forum Canadian users, post event and club info here.
HELP, Check Engine light + Hesitation
Old Apr 22, 2010 | 05:21 PM
VDOZA's Avatar
ON HELP, Check Engine light + Hesitation
Hi All,
My FC is at New MazMark Auto right now. 1991 N/A. It had a rebuild 2 years ago, with 1000kms on it since. It starts up fine. I have a high flow cat on it.
It runs fine for about 10 minutes then the Check Engine light comes on. And the vehicle hesitates around 3000rpm only when the Check Engine light is lit.
They've tried another ECU. No change.
I'm starting work soon and need it on the road to work this summer to save up for school in Sept.
Help guys! Sorry for such a newb post. And thanks in advance for all your help!
Nathan
(Rear seats anyone? LOL)
Old May 2, 2010 | 09:48 PM
misterstyx69's Avatar
Retired Moderator, RIP
Your OMP is starting to go.S5 engines are known to have the Crappy OMP from Hell!
Since they are Electrical,they will Send a signal to the ECU and put the engine into Limp MODE.
Check engine light comes on and it Goes all screwy,and you lose power,etc.
get the Codes off the Car,,and see what codes it is throwing out..I am thinking a17 or 27 or 28..something like that( If memory is correct)
Old May 3, 2010 | 08:12 PM
rd_turbo's Avatar
ERTW
Be careful with swapping ECUs. On S5s, bad OMPs will kill good ECUs and you'll be chasing a red herring. Many shops have learned this the hard way.
Old May 4, 2010 | 03:01 PM
Six Rotors's Avatar
So what code(s) have you pulled?Unless you have a code you are guessing.
Kyo
Apr 13, 2019 09:24 AM
ItsJBohmzB
171
Apr 24, 2017 01:11 PM
elfking
Aug 19, 2015 09:48 PM
