Need Help W/ ABS Delete
Old Apr 20, 2010 | 06:59 AM
turbodrx7's Avatar
PURIST
MD Need Help W/ ABS Delete
Alright, I decided to delete my ABS. Please dont ask why or tell me I should not have, thats not why i created this thread. I ended up picking up a rotary shack delete kit from a local that was selling one. It came with a wilwood proportiong valve and "all the fittings." The problem i am running into is that the adapters for the proportioning valve are not flared and dont use a crush washer to seal. They look like they relay on just the threads w/ some teflon tape to seal. If I am not mistaken, this definently will not work.
I have been looking for some 1/8 npt flared fittings or one that i can use a crush washer with to seal the proportioning valve, and i havnt found ****. Even on wilwoods site, they have just regular pipe thread adapters pictured with the proportioning valve. i found out that the 929 master cylinder is a M10x1.0 thread, which i assume is what all the other brake fittings are also. I guess what im looking for is an adapter from 1/8npt to m10x1.0.
Any help from some of the experts is appreciated. Im banging my head against the wall here cuz in a bout 2 weeks this will be the only thing holding my up from driving the car. i will get some pics of what came with the kit once i get to work.
Thanks,
Ausitn
Old Apr 20, 2010 | 08:27 AM
turbodrx7's Avatar
PURIST
Here are some pics with the supplied fittings and a link to their site.
http://www.rotaryshack.com/ABSdeletekit.html
Old Apr 20, 2010 | 07:40 PM
JTurtonRX_7's Avatar
EFR IWG 8374
when i got my bias controller it came like this
i just screwed em in with that red stuff on it (whatever it is) and I havnt had any leaks
so teflon tape should work
hope that helps
Old Apr 20, 2010 | 07:53 PM
EFR IWG 8374
you can even see on rotary shacks website where they used teflon tape on those threads
Old Apr 20, 2010 | 08:07 PM
turbodrx7's Avatar
PURIST
^Yeah, i have always been under the impression that the amount of pressure in a braking system will far exceed what the threads can seal without a flare. Maybe I am wrong?
-Austin
Old Apr 21, 2010 | 09:01 AM
muibubbles's Avatar
Bubblicious DEF.
wait so the line they give you isnt flared?? how does the line even stay in place?
Old Apr 21, 2010 | 09:21 AM
EFR IWG 8374
-Austin
nope it works, mines been working like that for a few years now
Old Apr 21, 2010 | 12:16 PM
Fd3BOOST's Avatar
Recovering Milkaholic
The fittings you have Austin should work just fine.
Aramir
Oct 18, 2015 02:39 AM
RuffRx7
Oct 1, 2015 03:08 AM
