Drifting Discuss Drifting and drifting techniques here.
S4 TII Diff to S4 NA
Old Apr 20, 2010 | 01:17 AM
Sleepless in Seattle's Avatar
Spare some Change?
May be a dumb question but does it work? Can i simply buy a used turbo diff and stick it in a 88' SE? I dont want to weld the diff just yet cause fiance will be using the car as well and from what i understand it gets pretty dangerous when its wet if you dont know what your doing.
Old Apr 20, 2010 | 01:22 AM
truebluegallo's Avatar
ull need a drive shaft an t2 axels also
Old Apr 20, 2010 | 01:25 AM
NoPistons!'s Avatar
Tango Down
Drill the plate the driveshaft bolts to on the diff.
You CAN slot your cv axles to fit the TII stubshafts as a temp solution but i recommend just going with t2 axles.
Pretty easy stuff. Good luck bro!
Old Apr 20, 2010 | 01:02 PM
Spare some Change?
Thanks man.
So correct me if im wrong,
The pieces i need without slotting,
x. TII Diff
x. TII DriveShaft
x. TII Axles? all the way to the hubs? or just the small things that stickout?
Old Apr 20, 2010 | 01:13 PM
FelixIsGod29X's Avatar
Manual Rack
Right now my S4 n/a has a t2 rear end/ half shafts. When i installed my n/a motor/trans/drive shaft i just had to slot the n/a driveshaft to mate to the T2 rear. Harder to explain then it is to do. I used a hacksaw and a dremel to do the job in 20min. Holding up fine for months now with some hard launches.
Old Apr 20, 2010 | 01:17 PM
Manual Rack
Originally Posted by Sleepless in Seattle
Thanks man.
x. TII Diff
x. TII DriveShaft
You just need/ what i did.
T2 diff
T2 axles.
keep your n/a shaft or get a custom shaft from mazdatrix.
If you want it 100% proper you will need
t2 diff
t2 axles
5 lug swap- do not need but why not while your at it
t2 driveshaft
t2 trans
t2 flywheel
t2 clutch
t2 clutch slave
t2 starter
I suggest doing what i did unless you seriously plan to go all T2 in the future.
Old Apr 20, 2010 | 08:52 PM
Qua_Ngheo's Avatar
felix will this also work for s5?
Old Apr 24, 2010 | 02:04 AM
Zerkster's Avatar
RTRY-FTW
yup
1NSIGHT
Drifting
Sep 29, 2015 12:18 PM
mulcryant
Sep 9, 2015 05:24 PM
