Rtek Forum Discuss the Rtek 2.0 and other Rtek ECU's
Rtek What injectors are yall using for 300+ whp
Old Apr 19, 2010 | 02:42 PM
66 impala's Avatar
I think i have an injector problem causing a lean issue and i was wondering what yall were using with the rtek? I have rc's 750/1200's.
Old Apr 20, 2010 | 05:37 PM
turbo2ltr's Avatar
Are those high or low impedance? And do you have the resistors installed?
Old Apr 20, 2010 | 10:50 PM
66 impala's Avatar
the 750's are high impedence "saturated" and the 1200's are low impedence "peak and hold" I have made a harness between the plug and the stock injector resister box to only give the 1200s more resistance.
Old Apr 22, 2010 | 04:03 PM
lastphaseofthis's Avatar
My job is to blow **** up
can you back probe at the ECU for exact resistance between them all?
Old Apr 23, 2010 | 08:03 PM
gxl90rx7's Avatar
destroy, rebuild, repeat
i was running lean with 750's and 1000's with about 300whp, correction maxed with 550/550 preset. i believe its because of the ecu's saturation-style injector drivers. you may have better luck with the FJO injector driver inline
Old Apr 23, 2010 | 11:59 PM
solareon's Avatar
I didn't have any issues. Are you maxing out the adjustment range? Did you have the injectors flow tested?
Old Apr 25, 2010 | 02:15 PM
66 impala's Avatar
Ill have to look at the wiring diagram and see if i can get some resistance readings at the ecu. I got flow sheets with the injectors when i bought them. gxl90rx7 are you running this injector driver? How did you fix your problem?
Old Apr 28, 2010 | 07:17 AM
gxl90rx7's Avatar
no i wasnt running any injector drvier. you dont want to know how i fixed it.. i found a good deal on a haltech
i tried upgrading to 1600's but it was too sketchy staging them
I am now running the same 1000cc injectors with teh haltech and im only hitting 70% duty cycle, same fuel setup. that is why i believe it was caused by the high-imp injector drivers in the stock ecu. the ecu is sending the right p/w length for the duty cycle you want, but it cant supply the current to open a low-imp injector quick enough, so you dont get the same fuel flow as with a low-imp injector driver like the FJO
Old Apr 28, 2010 | 12:41 PM
Silverfc88's Avatar
Running 720cc primaries and 1000cc secondaries. 14psi, 350 horsepower at 90% duty cycles. Correction set to 720/720.
Old Apr 29, 2010 | 09:26 AM
66 impala's Avatar
Im happy with the cars power if i can just get it to stop leaning out. I thought about selling this and getting a haltech but i dont wanna deal with wiring up a whole new harness right now. The 750's that i have are high impedence and the 1200's are low impedence. Can i run 2 channels of the 4 channel FJO driver on the 1200's?
Old May 5, 2010 | 11:22 PM
Chris Boots's Avatar
I blame the TPS
Hmm I have a dyno sheet saying about 300hp with one of my TII's with 720/720's. although that engine does have a race port in it, perhaps thats why.
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
connerfd3s
Sep 19, 2015 05:58 PM
dillrx7
Sep 7, 2015 09:38 AM
