Coffee can under the hood.
Old Jun 20, 2002 | 09:04 AM
metalliman's Avatar
Does anyone know the purpose of the coffee can (charcoal canister) under the hood of an '83. I assume it's some kind of filter, maybe for the gas tank? Can I get rid of this, and just splice the tubes together.
Old Jun 20, 2002 | 11:41 AM
Richard Miller's Avatar
Damn, it did start!
it has to do with the emissions, part of the breather system if i am correct. other than that i am curious of that myself.
Old Jun 20, 2002 | 11:46 AM
It's for the fuel vapors from your gas tank, if you take it out you'll have to vent them somewhere else like straight into the atmosphere which isn't exaclty healthy, hence they charcoal canister.
Old Jun 20, 2002 | 11:54 AM
WackyRotary's Avatar
standard combustion
Dude, unless you go with a aftermarket setup or go Paul Yawing on your carb, just leave it alone. It is the evaperative emission control canister. When its warm out, gas evaperates and pressurizes the gas tank, once a critical pressure is reached, some of the vapor is released and directed to the canister. They can hold about a 1/2quart of gasoline liquid in vapor form if I remember the correct figures. When the engine warms up, a solinoid releases the vapor into the carburator and you "purge" the canister. This is good so you don't loose vapor to the air and can use it also....
Its required by law to have....espeically important in the LA basin were HC's do a lot of harm in the air there causing photo chemical smog.
Old Jun 20, 2002 | 11:55 AM
inittab's Avatar
I read your email
I don't what you guys are talking about.... I get cups and cups of delicious fresh coffee outa mine every morning.
Old Jun 20, 2002 | 04:13 PM
SilverRocket's Avatar
EliteHardcoreCannuckSquad
Whatever setup you have, stock or aftermarket, don't remove it - leave it there. If you need somewhere to run the line from the canister to, run it to the nipple on the center housing on the driver side of the engine near the oil filler (like 82's are setup stock).
Old Jun 20, 2002 | 09:20 PM
HOZZMANRX7's Avatar
Driving RX7's since 1979
Decaf or regular?
Old Jun 20, 2002 | 10:24 PM
Project84's Avatar
Open up! Search Warrant!
Re: I get cups and cups of delicious fresh coffee outa mine every morning.
Originally posted by HOZZMANRX7
Decaf or regular?
I have a mod on mine that lets me get cappuccino
Coochas
44
Nov 5, 2019 11:08 PM
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
