Aftermarket oilcooler.
Old Apr 13, 2010 | 07:28 PM
vj226966's Avatar
GA Aftermarket oilcooler.
My 79 has a fmoc. Coming home from work i got a hole in it. Its shot.My boss went and got me a universal mount cooler.Will this work or do i need to switch to a beehive? I already have the other hooked up, but havent drove it home.Will this cool my car?
Old Apr 13, 2010 | 08:12 PM
vj226966's Avatar
Anyone? My wife wants her car back. Most of all i dont want to kill my 7. Will a 2nd gen fmoc work?5 days without my car is killing me.
Old Apr 13, 2010 | 09:04 PM
Verneuil's Avatar
Idk anything about why after market coolers dont work without modifying them. I think you need to somehow restrict how fast the oil goes through. I know on that stocker of urs, thers a removable oil pressure re stricter. If you can adapter that to the new one i think you would be fine. Btw does that new one have a fan on it? if it does that would benefit you more. Hope this helps and someone adds to this.
Old Apr 13, 2010 | 09:20 PM
Jeezus's Avatar
Stu-Tron Get Yo Groove On
2nd gen's will work. Search the forum, Trochoid did a write up of it.
Old Apr 13, 2010 | 09:21 PM
Sgt Fox's Avatar
Stigulus Moderatorai
Second gen FMOC would work fine. You can't get much better than that. Also no flow restriction is needed, the stock oil cooler has a thermostat which is what you may be thinking about.
Old Apr 13, 2010 | 10:05 PM
Verneuil's Avatar
Ok gotcha, Thought it was a pressure regulator. But a thermostat makes more sense
Old Apr 14, 2010 | 02:13 AM
Sgt Fox's Avatar
As for the aftermarket, give us some specs and pictures... it may be good enough. Hard to beat the Mazda FMOC though.
Old Apr 14, 2010 | 06:16 AM
vj226966's Avatar
i dont have pics, but its Napa brand. its about 1 foot long almost a 1' thick. It mounts to radiator. my friend says its way smaller then fmoc but bigger then beehive but dosent have coolant going through it.
Old Apr 14, 2010 | 06:57 AM
mazdaverx713b's Avatar
Have RX-7, will restore
probably not big enough..i would not settle for anything less than an oem oil cooler, first or secong gen..post a want to buy ad in the first gen parts for sale/wanted section here on the forum. you may want to replace the oil cooler lines as well.
Old Apr 14, 2010 | 06:09 PM
vj226966's Avatar
I am going to do the right thing.My friend has a crap load of 2nd Gen Fmoc, and i am going to buy one off of him. Thanks for the input.
renjiv2
57
Jan 25, 2024 03:34 AM
