Why am I destroying my tire?
Old Apr 13, 2010 | 12:18 AM
zephyr07's Avatar
Last spring I replaced my fb's stock suspension with tokico hp's and racing beat springs. With 15x7 +20mm konig rewinds I really didn't have any tire rubbing issues. Since then, I replaced the tires on the car last summer with toyo proxes (205/50/15) which are the same size but different brand as what was originally mounted on the rewinds. However now, I just got the car out of storage and cannot take a fast right corner or hit any bump with the wheels turned without the left front tire scraping against the fender. This is pulling the lip of the fender down toward the tire while also cutting into the tread. I'm unhappy with the rb springs and was planning to replace them with re-speed coilovers, but will that solve my problem? The car is sits noticeably lower on the driver side and the left front is the only tire that rubs. Why didn't I have rubbing issues last season? Did the springs really "settle" that much in storage? I would prefer not to roll my fenders, but if it solves the issue so be it. Maybe racing beat should revise their spring design after I've read so many complaints about them on the forum.
Old Apr 13, 2010 | 01:37 AM
jshiz's Avatar
Actin Like I'm Drunk
I like my racing beat springs but i have them paired with some KONI struts. But I'm running a low offset (-10) wheel so i have rubbing issues. But when i use the stock GSL SE wheels (+40? offset), i don't have any issues.
I'm gonna just roll my front fenders and call it a day.
Old Apr 13, 2010 | 02:09 AM
woodonastick's Avatar
my fb is older than me
roll your fenders. ive had 205/50/15 on my fb with rb springs and didnt have a problem with rolled fenders.
Old Apr 13, 2010 | 02:11 AM
Rx Seven's Avatar
Can You Wankel?
Different model tires are often different in physical size even though they may be both listed at 205/50/15, they can often have different shapes. And if the RB springs where new when you put them on they will settle a bit over time.
1st gen also tend to sag on the left front corner and IIRC there is a shim you can purchase from Mazdatrix(?) that will raise the left front corner.
Old Apr 13, 2010 | 07:54 AM
Keith13b's Avatar
Have you checked your tire pressure? If the setup didn't rub, and now is rubbing after storage, I'd check the tire pressure and functionality of that front strut, along with all the bushing, etc. I've had similar problems in the past (rear wheel rubbing) and the tire preessure was down about 3 psi. Also make sure the springs are properly inserted in the perch's.
Old Apr 13, 2010 | 08:06 AM
zephyr07's Avatar
I'll check the pressure, though it looks fine. The springs were new when installed and I was planning to replace all the bushings when I got re-speed parts. The car sits almost an inch lower on the left side, why do they all have that tendency? I've heard about the shim, but it kind of defeats the purpose of having a nice slightly lowered car. My car sits about the same as stock height if not higher on the right, I think the shape of the new tire is the problem here, might as well roll the fenders and order coilovers.
Old Apr 13, 2010 | 11:22 AM
j9fd3s's Avatar
Community Builder
you can't tell the tire pressure by looking, unless the tire is almost completely flat.
they sit lower on the driver side because the driver, battery, steering box and brake booster/master/pedal assy is all on that side.
if the tire is hitting the fender, negative camber will help too
Old Apr 13, 2010 | 02:35 PM
thunkrd's Avatar
i'm a poser
agrees with j9, get some camber plates and you shouldn't have any more problems
Old Apr 13, 2010 | 02:48 PM
jshiz's Avatar
It'll cost a lot less just to get the fenders rolled. And you don't have to worry about the inside of the front tires wearing out quicker than the rears.
Old Apr 13, 2010 | 11:38 PM
zephyr07's Avatar
I checked the tire pressure and it was good, I'll probably just wait and see how things go once the coilovers are on, as I was planning on buying them anyway.
Old Apr 14, 2010 | 10:46 AM
orion84gsl's Avatar
My 7 is my girlfriend.
Could be the spring may be weak, but I've had RB springs for 3 years with no noticeable difference in height, so an inch is a bit much for just sag. Perhaps your damper is leaking or blown. When you swap to the RE-speed parts, check your dampers while you have everything apart.
rx7jocke
72
Jun 17, 2016 03:48 AM
