How to load map on Haltech e6k?
Old Apr 11, 2010 | 04:02 PM
TwEaK's Avatar
Rotors? What Are Those?
i figured i would ask here since the haltech section usually takes a few days to get a reply.. i finally got an old laptop with windows 98 dedicated just for the Haltech.. Anyways i downloaded a map from hitman's website so i can have a starting point and now confused on how to load it onto the Haltech
Thanks
TwEaK
Old Apr 11, 2010 | 05:41 PM
gxl90rx7's Avatar
destroy, rebuild, repeat
you need software first
http://www.haltech.com/index.php?opt...d=69&Itemid=65
Old Apr 11, 2010 | 05:45 PM
TwEaK's Avatar
i have the software loaded onto the computer already.. problem is putting the file from my desktop into the haltech or to where the haltech can read it
TwEaK
Old Apr 12, 2010 | 01:02 PM
beefhole's Avatar
Boosted. I got BLOWN!!!
This is easy. Connect your computer to the haltech, and switch the key to ON. Then turn the computer on, and start up the E6k software. When you run the software, at the first main screen, press "Y" to select online mode. There will be a loading bar at the bottom, and it should load quick. After that, you are online. Next, press alt-f and select load map. Then pick the map you want. When you load a map, a progress bar will come up. It's pretty slow though, loading a map into the E6k.
PS
Also before loading any map, SAVE the map first when connecting to the haltech just in case you need to back track.
It helps to have the maps in the same directory as the e6k executable file, that way you can find them faster.
Old Apr 12, 2010 | 10:26 PM
TwEaK's Avatar
when i do that it says something about access denied.. i was able to load it onto the haltech software now the problem is it reading.. this thing is a pain in the *** any other ideas?
TwEaK
Old Apr 13, 2010 | 05:55 AM
beefhole's Avatar
Don't know much other than that, as i've never had problems. Make sure the file isn't read only maybe? Also on my computer, when running from a windows 98 dos prompt, my software does not work. When I boot up, I press f8 and select command prompt only and start the computer in MSDOS mode. Only then will my software work. What version are you using? I'm using v634, heard that was the best one.
Old Apr 13, 2010 | 11:21 AM
1SWEET7's Avatar
Now With 10th AE Fun!
Do you have to use windows 98 for the Haltech? XP doesn't work?
Old Apr 13, 2010 | 11:46 AM
beefhole's Avatar
XP might not work without a dos emulator. I didn't bother as I have an old laptop I can use anyway.
He's On Toroids
NE RX-7 Forum
48
Oct 19, 2015 08:58 PM
killerrx710
Sep 24, 2015 10:57 PM
