1984 RX7 GSL SE..I replaced the plugs
Old Apr 11, 2010 | 01:18 PM
TroyNic's Avatar
Troy
recently and found the leading ignitor was bad, so I picked one up on the site here and installed it, no problem..today I pulled the T2 wire off the distributor when the car was running and noticed no change..odd..? even for a novice such as myself this does not seem good..waiting for it to cool off and then I will make sure the plug isn't fouled...any ideas..?
Troy
Old Apr 11, 2010 | 01:27 PM
OneRotor's Avatar
RAWR
You don't need trailing plugs to run. They contribute to between 3% and 5% of your power. They are there for emissions.
Old Apr 11, 2010 | 03:43 PM
74RX4's Avatar
Round and Round
Pulling a trailing plug will not change the idle much. It's not like a piston. Pulling a plug wire stops 1 piston from firing. Since a rotary has 2 plugs in each chamber, pulling 1 does not stop the chamber from firing.
alphawolff
Nov 17, 2015 05:57 PM
Joe428
16
Aug 19, 2015 06:24 PM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
86rxNa
Aug 11, 2015 11:51 AM
