Does drum brake auto adjust work?
Old Apr 8, 2010 | 12:48 PM
DenCon's Avatar
After much trial and error, I have the drum brakes adjusted fairly well; but removing the drum every time is a hassle; and it's darn difficult to get to that little adjustment window behind the brake plate.
Can fine adjustment be done by backing and braking?
What's the trick (if there is one)?
Old Apr 8, 2010 | 12:49 PM
BlackWorksInc's Avatar
Wrkn Toyota, Rootn Wankel
As far as I know, you shouldn't have to back off the star wheel everytime you remove the drums, have you machined your drums to remove any lips?
Old Apr 8, 2010 | 01:00 PM
j9fd3s's Avatar
Community Builder
drum brake adjusters never work. in the 1 in 100 time they do, be happy and surprised
Old Apr 8, 2010 | 01:04 PM
t_g_farrell's Avatar
Waffles - hmmm good
I've found in general, with star adjusters, if you don't start with new
brake hardware they rarely function very well when you do the backup
and stop procedure.
Also having the drums turned to remove any lip, as demon suggested will
make it easier to remove next time.
Ultimately the final adjustement needs to be made with the drums on and
using the window to push the star around with a screw driver.
Old Apr 8, 2010 | 01:45 PM
mazdaverx713b's Avatar
Have RX-7, will restore
often times the adjuster is actually rusted or seized from brake dust and must be removed and freed. i always clean and regrease the adjusters. if you are that far into it, replace the brake shoes and inspect the drums for wear. adjust them by hand with new components and everything will work well!
Old Apr 9, 2010 | 10:25 AM
DenCon's Avatar
When we replaced the pumpkin, we cleaned everything and it all looks excellent; the drums are in good condition (no lips). It's just that that little plug is a b!tch to get to...
alphawolff
Nov 17, 2015 05:57 PM
josef 91 vert
23
Sep 3, 2015 11:20 AM
CaptainKRM
14
Aug 26, 2015 09:52 PM
Frisky Arab
13
Aug 18, 2015 05:30 PM
GrossPolluter
Aug 16, 2015 09:50 AM
