Rotary Drag Racing The place to post your racing stories and info
Question for the guys running et streets
Old Apr 6, 2010 | 07:53 AM
justturbo2's Avatar
Registered User
For the guys running mickey thompsons et street or similar slick, do you slip your clutch out of the hole or do you just dump it.
Old Apr 6, 2010 | 08:34 AM
zinx's Avatar
_________________________
Dump it. You want those tires to bite in and wrinkle up.
Old Apr 6, 2010 | 09:26 AM
JStrib's Avatar
Recovering Rotary Guy
Drop the hammer and hold on
Old Apr 6, 2010 | 09:38 AM
sk8world's Avatar
Chasing numbers
8k and drop the hammer! BUT do you have upgraded LSD? Brace?
Old Apr 6, 2010 | 09:52 AM
justturbo2's Avatar
Registered User
Ok i guess i will be dropping the hammer.
At what rpm are you guys doing this?
Is everyone dumping it about 7-8k?
sk8world, yes i got a kazz with a pfs diff girdle/brace and the upgraded axles from driveshaft shop.
Old Apr 6, 2010 | 10:36 AM
Indian's Avatar
It wasn't me!!
I would start from 6k then move up... watch your 60ft and see which one is better. Also make notes (mental or written) on track conditions.. Launching 7k in the day might not work at night or a less prep track...
Most successful racers knows how to work the track..
oh, you have all the goods to launch like a maniac. Let her rip!!
Good luck
Old Apr 6, 2010 | 01:50 PM
justturbo2's Avatar
Registered User
Thanks guys.
Also what tire pressure 12-15psi right?
Old Apr 6, 2010 | 04:05 PM
zinx's Avatar
Start at 15 and work your way down in 1/2 psi increments. Make sure you have a good, accurate gauge.
And as Indian said, you'll have to work the track. It will always be different.
Old Apr 7, 2010 | 07:09 PM
turbo10th's Avatar
Agreed Rev(i go to about 7-8k) Dump It. But without skinnies i wouldnt go much under 15psi. Someone told me that but didnt believe them till i went down the track the rear sways real bad(had to let off at one point). Mainly because when you try to do a small correction, normal tires will want to over correct. Got skinnies and now run around 14psi warm. Now i do have a T2 LSD and no brace yet but going to soon since i just broke my first axle after about 10 10 sec passes with 1.5 0-60's(and some other passes).
Old Apr 8, 2010 | 06:08 AM
blitzboy's Avatar
I load up on the handbrake on the line then dump the clutch and handbrake approx 7k rpm.
Running Skinnies and ET streets with 12 psi in the rear and 28psi up front.
Regarding breaking axles I broke my first one last October, have now upgraded to Stillway axles. Going for big launch at my next race round next month, hoping for low 10s and maybe a 1.3x 60ft
Old Apr 8, 2010 | 07:29 AM
justturbo2's Avatar
Registered User
Turbo 10th, I forgot to mention I did purchase a set of shinnies. SO hopefully all goes good when I go to the track. Thanks for all the info guys. Keep the comments coming either it be big or small
Old Apr 8, 2010 | 10:12 AM
beefcake's Avatar
pushing s##t up hill
ive got mt slicks and load up the driveline, i slip it off the clutch at 8300 and i have a best of 1.3 60ft time.
I have a 100% stock drivetrain, and mid 400hp with 8.5 inch slicks .
Im going to try and break something this weekend, got two step now and im going for 8500 slips or dumps haha
Old Apr 11, 2010 | 02:15 PM
RX794's Avatar
NYC's Loudest FD
Dump away!!
Clacor
Aug 14, 2015 09:17 AM
Wolf_
Aug 11, 2015 04:23 PM
