Haltech PS1K and Electronic OMP
Old Apr 5, 2010 | 02:30 PM
Poindexter10thae's Avatar
AKA Poindexter
Has Anyone tried to run the electronic OMP with the PS1K yet? I can only assume it work as there are direct plug in patch harnesses available from haltech for both the S5, FD, and the RX8. I currently am a proud new owner of a PS1K, got the Long flying lead kit. Just recently switched from a microtech LT10S w/x4 box. I was running individual MSD coils and will be retaining those with the new EMS.
Still in iraq and havent had a chance to read my manual yet, what is the best way to wire up the EOMP and set up the software if possible?
Havent seen many people in the base map thread with a Half Bridge, any base maps available yet?
Old Apr 5, 2010 | 05:47 PM
FJDRX7's Avatar
Back to the DrawingBoard.
send me your email and i will send you the diagram for it, is easy to connect to the new one, i just did mine as well and yes im heading back your way in a few days again lol
Old Apr 5, 2010 | 06:39 PM
AKA Poindexter
poindexter10thae@gmail.com
Old Apr 6, 2010 | 07:52 AM
Claudio RX-7's Avatar
EFI Tech Wannabe
The OMP can be controlled through the Haltechs no problem, its a feature thats been available since the E8/E11s and still found in the Sports, you wire up the OMP's stepper motor to the Stepper motor output wires (IDLE 1-2-3-4), there are power and position (feedback) signal wires, and the setup is quite straight forward, once you have it connected and enabled you simply go to the OMP map and dial in your oil injection curve based on throttle position. Giving you the flexibility to run what ever oil % ratio you want.
Old Apr 13, 2010 | 01:09 AM
agentsmith39's Avatar
can this be done with the sprint re?
Old Apr 13, 2010 | 03:43 AM
C. Ludwig's Avatar
www.lms-efi.com
That's already been answered. The answer is still no.
Old Dec 31, 2010 | 01:18 AM
t-von's Avatar
Rotor Head Extreme
Do you have a diagram to wire the 20b OMP? I have the E11 with Milispec harness!
Old Dec 31, 2010 | 09:58 AM
C. Ludwig's Avatar
www.lms-efi.com
www.lms-efi.com/haltech/diagrams/OMP03.pdf
Old Dec 31, 2010 | 09:41 PM
t-von's Avatar
Rotor Head Extreme
Originally Posted by C. Ludwig
Perfect Thx!
Old May 13, 2011 | 11:06 AM
t-von's Avatar
Rotor Head Extreme
Damn I thought I saved this! Link doesn't work any more.
Old May 13, 2011 | 04:01 PM
C. Ludwig's Avatar
www.lms-efi.com
Moved stuff around on our hosting sites a bunch the last few months. Send me an email and I'll foward it to you.
ludwigmotorsports@insightbb.com
Old Aug 9, 2013 | 04:55 PM
t-von's Avatar
Rotor Head Extreme
Hmm now that I got my engine running again and have the omp enabled, it seems I may be injecting too much oil. Is the base oil map over rich? David Hayes was having a similar problem.
Old Aug 10, 2013 | 11:30 AM
j9fd3s's Avatar
Community Builder
this is the factory info for the metering pump, its S4 vs S5, cc/per hour is really not very convenient, but unless someone posts the map from the ECU, we really don't have a lot of info. the apex seal temp vs cc/hour graph is at full power
Andrew7dg
Aug 6, 2017 01:41 PM
TeamRuffRacing
Sep 30, 2015 08:13 PM
