Had A/C on and my overfill take was filling up
Old Jun 19, 2002 | 03:03 PM
Ok I was driving around today it was a pretty hot day and I had the A/C on. I just get to school let my car cool down for 2 mins, shut it off and im walking away and I hear a bubling sound. I pop the hood and I see my coolant overfill tank filling up. So I start the car I see my temp gauge is going above the half way point so I turn on the heat. The coolant stops going in the tank and my temp is droping a lil under half and everything is back to normal.
Im afraid to turn my A/C back on, any one know what the problem is?
Thanks
Old Jun 19, 2002 | 03:41 PM
banzaitoyota's Avatar
What Subscription?
Have your coolant system pressure tested. Cold be a coolant seal leaking under heavy load. Radiator condition? How old is your coolant? Oil Cooler fins clean?
Old Jun 19, 2002 | 03:43 PM
KNONFS's Avatar
B O R I C U A
Do you have the stock fan? If the answer is yes, check that the clutch fan is working properly. If its working properly, have the system pressurised.
If you have a e-fan, some other issues will apply!
Old Jun 19, 2002 | 05:18 PM
TonyTurboII's Avatar
Glock Lover
I had the same problem in my Explorer. Based on colling system theory, it should relate. I had a faulty thermostat.
Coochas
44
Nov 5, 2019 11:08 PM
Turblown
Sep 30, 2015 05:58 PM
Devon Murray
Sep 25, 2015 09:41 AM
