radiator question.
Old Apr 2, 2010 | 02:12 AM
ventuno21's Avatar
radiator question.
would it be possible to use an na radiator in an t2 application?
Old Apr 2, 2010 | 02:22 AM
Howru's Avatar
I
Yep, they're the same.
Old Apr 2, 2010 | 02:23 AM
ventuno21's Avatar
thanks sir how about a diffrence between s4 and s5?
Old Apr 2, 2010 | 02:41 AM
Howru's Avatar
I
Some, usually early, s4's had the pressure cap on the t-stat neck and none on the radiatior.
Others ones have a fill cap on the t-stat neck and pressure cap on the rad.
s5's have a pressure cap on a small extension near the battery and a plastic t-stat neck with no fill neck.
Old Apr 2, 2010 | 02:51 AM
ventuno21's Avatar
so if my freind per say had an s5 radiator i could use it in my t2 ?
Old Apr 2, 2010 | 03:00 AM
Howru's Avatar
I
Yep. If you have the overflow tube hooked up to the cap on the t-stat neck, you can move it to the one on the rad and install this (http://www.mazdatrix.com/getprice.as...m=15-17Y0-N323) on the t-stat neck to convert it to a fill point.
Old Apr 2, 2010 | 03:15 AM
ventuno21's Avatar
thanks so much sir ive potentially saved a grip of money.
vish86
Interior / Exterior / Audio
Oct 1, 2015 11:53 PM
MidnightOwl
Sep 25, 2015 10:24 PM
